trafficinsight
HELICOPTERS ARE NOT AIRPLANES!
I love the unruly mob theme of this post!
Well, with a little help on systems anyway![]()
The VNAF does not approve of that pic.
What? It's not like they're going to need that thing anymore.
Here's 'Landseaire', a flying yacht (PBY).
For singles not on floats the AT802 is friggin' mean looking!
You beach it? Seabee will hold up in rougher waters then any float plane.
Mike, is there a reason the gear doesn't fully retract? It seems like leaving the exposed tires would be pretty vulnerable, even to small arms (if they could even hit it?). Obviously a bullet in the tire is a lot better than losing a wing, so was it a design choice between the exposed gear and somehow weakening the rest of the plane?
/curious bystander
Great info. Thanks.
Here's a pic of how it sits on the runway with gear up. On the mains and dragging the tail.
Neat! Did the cannon not like the sudden deceleration?
No, the cannon was the reason for the gear up landing. The attitude you see the jet in, is the attitude it lands in.
We'd had ammo problems with the gun for a couple of years, where there were a few incidents of a 30mm round detonating inside the gun before being fully loaded/seated or slow burning. This resulted in the gun barrels, feed mechanism, and gun drive getting destroyed, as well as damaging the airframe next to the gun and sending debris to the stowed nose landing gear thats right next to the gun. This ended up jamming the nose gear in the up position and necessitating the all gear up landing, even though the main landing gear came down fine. Never want to do a nose-gear up landing. The damage to the gun was pre-landing.
What is so bad about a nose-gear up landing in the A-10. We've all seen "normal" airplanes do that just great - what is it about the A-10 that makes bailing out preferable?
