Nark
Macho Superpilot
Seriously? Just idle then...
Flight Idle is term used for Turbine engines to delineate between minimum idle on ground vs flight. Not the same.
lol Really? Might wanna turn the gain down just a touch.Flight Idle is term used for Turbine engines to delineate between minimum idle on ground vs flight. Not the same.
It's probably -40C, that damn thing will probably climb 1000 lbs over gross at flight idle on a single engine.
No way.
find a hobby son...
exaggerated...
It's making sure you know where you sit on the food chain, kid.
Anyone know this guy? I am willing to bet better than even money he is less than 30 years old. Just a hunch.
hold the camera and watch this...Heaven forbid someone have...FUN (gasp)...in an airplane.
Not that I've ever flown the western shoreline of the Chesapeake Bay from Annapolis to near Norfolk at 20', but my old CP told me that if I ever did, to make damn sure I have a little nose up trim in. That way, if I got distracted, I'd climb gradually instead of descend.
Two motors and you're practically at sea level! Other than not being turbines, what more could you want? The pilots are probably wearing survival suits.
Just don't pull a Titanic, and you're good to go!
It's probably -40C,
Yes there would be.
The ocean doesn't freeze, nor does fast moving water.
He speaks the truth! I've personally seen open ocean breaking out between sea-ice when its -40.
