Blimp Questions
Gonzo
What is the top speed?
What kind of range do you guys have?
Are any of you guys flying the blimp in Atlanta this week?
Well,
As far as speed is concerned, the best answer is "it depends." Airships are much more affected by wind than other types of aircraft, so knowing what the winds will be doing is always a critical portion of our flight planning.
The airship I'm currently flying has a Vmo of 48 Knots indicated. Since I've been flying, I've seen ground speeds anywhere from 10 knots (that day was brutal) to 52 knots. Of course cruise speed also depends on the cruise power setting we use. 25-35 knots over the ground is usually about normal on a relatively calm day.
As far as range is concerned, once again, that depends on our power setting and the wind conditions we experience. The a-60 airship I currently fly holds 69.0 gallons useable fuel. 2400 RPM gives a total fuel burn of 6GPH. At 2500RPM the cumulative fuel burn (both engines) is 7GPH. At maximum continuous power (2600RPM) you're up to just over 8GPH (these figures are for the Limbach engines, not the Rotax).
The longest I've currently spent in the airship without refueling or getting out was a hair over 10 hours.
The two models that I fly at this company have either twin 80HP Limbach L2000 ECI engines, or Twin Rotax 912F3's. There is no mixture control for either.
Oops,
And to answer your other question, yes, one of our Metlife airships was in Atlanta earlier this week.
Mark815 said:
I have a dumb question, but I've always been curious, how high can those things go?
Maximum operating altitude for the A-60+ is 10,000' MSL. It is 6000' IIRC for the Rotax model. You have to remember though, the purpose of airships is generally advertising or aerial coverage for events. Therefore we usually spend our time below 1500' AGL or so.
Also, how high we can go depends on a phenomenon called "pressure height". We can't fly above pressure height without dumping helium. Pressure height varies with temperature, elevation (pressure) changes, as well as the quantity (mass) of Helium inside the envelope, among others.
Certain things you would never think about in an airplane are actually quite critical in airships.
How do you know when to add helium to the envelope? How often is that done?
What is the life-limiting number for blimps (e.g., cycles, years, time between windstorms)?
It depends. The airship I'm currently on leaks about 2-3 Helium bottles per day. Each bottle is 291 cubic feet. When we add Helium depends on quite a few variables.
X-Forces said:
Do blimps have a VNE??
If so, what happens if it's exceeded?
Yes, we have a Vmo. It's 48 knots indicated on the one I'm currently on, and 52KIAS on our Rotax models.
It is extremely difficult to exceed Vmo in these things. In fact, I'm really not sure how you would be able to be in a situation where it could be exceeded. Even at max power you're usually nowhere close to Vmo. Even in a steep descent, your pressure limits would be exceeded before reaching Vmo.
Just like any aircraft, structural damage is a possibility above Vmo.
In airships, airspeed isn't really as important as it is in airplanes. We are much more concerned with pressure control and management, as well as static condition.
Planning is much more detailed in these things than anything I've ever done in airplanes.
Thanks for details Apophis. I love airships and have a collection of pictures of them flying in our woods. I am always staying at a distance, usually higher, ask the driver if he is on the frequency, then take a shot. Amazingly beautiful looking creatures.
No problem, Fencer. Especially considering how awesome your SU-24 thread has been with all the photos and information!
Airships are frequently thought of as slow and ungainly, but I'm really enjoying flying these things. It's such a unique and rare form of flight.
I find the term "creature" to be quite accurate. An airship really is like a living, breathing creature. They have to be taken care of and are quite fragile.
A member of our ground crew always stays with the airship when it's locked on it's mooring mast, 24/7. Basically he or she watches the airship, ballasts it according to the changing conditions, and takes hourly pressure readings and monitors everything.
They really do have to be "babied"!
One more question - do you guys have an air conditioner? Sometimes it's so hot and you don't stay high enough for cooler temps.
wow I didn't realize that! That's pretty crazy!
I want to know what sporting events you have been above Apophis? And is it feasible to break it down to ship it from NYC to LA?
Nope, no air conditioning. The right side emergency exit window is removable, which we do on hot days, also the pilot and front passenger windows can be slid open, which we also do on hot days.
Do people ever use the helium to make their voices sound funny?
Does that ever get old? :)
Right now, I've only been over some minor league baseball games. I'll be on our TBS themed Conan O'Brien airship starting tomorrow doing MLB playoff games. That contract goes until the middle of November. Our Metlife airships do golf tournaments, as well as NFL games on Sundays among others.
Also, if you've seen the DirecTV airship over the US open (tennis) or NFL games, that's also our company. I don't fly the DirecTV airship, it's a much larger model with a 170,000 cubic foot envelope.
As for your other question, if we have to go across country, we generally fly the airship there. It takes awhile, especially if there's weather that delays us. Generally the airships are only deflated and packed away when we send them to do overseas contracts, or once a contract for a particular ship ends. The Conan contract I mentioned earlier ends in November, and after that, that particular ship is going to be deflated. I'll then move to another operation.
Hah, nope. Helium inside the replenishment tanks is under very high pressure, plus, it gets very very cold as the gas expands leaving the cylinder. Not a good idea to be breathing that!
