...Most of the time they seem to think they're too busy to let pilots read back clearances either.
Well, I guess when you taxi out 120 departures in an hour during a rush, while alternating departure fixes to four different departure runways while coordinating with the other (sometimes TWO) other ground controller, we should save some time to hear you say, "A, A7, T".![]()
2−4−3. PILOT ACKNOWLEDGMENT/READBACK
a. When issuing clearances or instructions, ensure acknowledgment by the pilot. If no acknowledgment is received, attempt to re−establish contact. If
attempts are unsuccessful, advise the FLM/CIC.
NOTE−
Pilots may acknowledge clearances, instructions, or other information by using “Wilco,” “Roger,” “Affirmative,” or other words or remarks.
REFERENCE− AIM, Para 4−2−3, Contact Procedures.
b. If altitude, heading, or other items are read back by the pilot, ensure the read back is correct. If incorrect or incomplete, make corrections as appropriate.
Unwritten rules suck.
ORD is an acquired taste to be certain, a lot of our pilots from other bases are scared to even go there which cracks me up. I find the place amusing most times - for instance we once taxied to the gate without talking to a soul since being cleared by tower to land. From the north side clear to the south side.
Oh and while I'm at it, for you relative noobs to ORD (Xjet, ASA fresh SkyW captains) need to learn some 'box' etiquette. Keep it tight, move down when there is room and for *bleeps* sake don't park sideways!
Yep, an acquired taste to be sure.
I'm sure the faa performed careful analysis to ensure any deviation caused by not being able to read back an ord clearance would be solely the crew's fault.
...for instance we once taxied to the gate without talking to a soul since being cleared by tower to land. From the north side clear to the south side.[ /QUOTE]
Believe me, ground saw you, and figured, "SkyWest...probably making his way to the fox gates."
Thank you!!! Along those same lines, nothing worse than a United Airbus taking up an entire half of the box when I'm trying to fit six more RJ's in there!
Believe me, ground saw you, and figured, "SkyWest...probably making his way to the fox gates."![]()
Oh I figured so, I usually assume you guys are quick to notice those of us who know what we are doing![]()
Also Metering will give amendments to routing when weather is bad so that ground isn't tied up with people copying.
ORD is definitely an acquired taste. I started out hating it, but it was because I didn't understand how things moved or worked there. Now I love how efficient it is when I have to sit in JFK waiting and waiting because there is only one person working ground and 40 aircraft trying to get to one runway. ORD knows how to move aircraft! Now, the signature ramp control at ORD is an entirely different story...lol.
"Ok....push...who's calling for push? Eagle flight...what gate? Yeah you're cleared to push...Jetlink, taxi....ahh...west...east....west....west line to metering...oh....oh no, who, Eagle flight did you push? I cleared you to do what? Oh no, now the alley's backed up....ahh....ahhh...ahh...."
