XJ Saabs and Supplemental Air
v1valarob
So 9Ls first flight with an XJ Saab was supposed to be tomorrow. We are just waiting on approval for the new CFM. Only real difference between 9L and XJ Saabs is age, and the supplemental air.
My question is... Does the supp air ever work? And if it does work, how good is it?
We don't have a b+. It's a straight b.
I just walked down to SPs office and asked "are you sure those aircraft don't have longer wings?" he said no.
Maybe I'll just get my damn tape measure out. Or when someone follows the yellow line pulling into an IAD gate and goes wing tip to wing tip to another Saab, we'll know.
I guess only 30 were made with the extended wings. Maybe XJ doesnt have any BUT they do exist
I just asked the guy so I will get back to you.
That super clean, new car smellin white one in the hangar is for us?
Indeed it is. Supposed to fly tomorrow, but 2 or 3 of the 6 changes to our CFM haven't been approved yet. Scott was told less than 2 weeks ago on a Friday evening "we want those flying for us next week." Needless to say getting everything approved in that amount of time, with the FAA out of business is pretty tough.
Proposed checklist changes
What the hell is supplemental air? And what the hell are u doing fri night Rob? I'm stuck in ur area of the country
I'm imagining it's like the vapor cycle machine on the 1900's (aka air conditioning that operates indipendent of the bleeds/ packs)
It's a winnebago air condition with a fan. Placed in the back by 13 (or whatever row) A it can, when working correctly, knock the heat and humidity right out of the air for about 4 rows surrounding it.
Take care of it, it's one of the best ways to get the Saab cabin below 80F before takeoff. It shuts off as part of the load shedding during start, so a wise FO will turn it off prior to turning 2 and only after 1 started and the CA has hit the gen/reset or whatever it is called.
Is Supplemental AC the reason you guys would taxi around with the right prop running in feather in the summer?
No, we can open up a high pressure bleed valve to get more A/C on the ground, but the prop must be in feather to control temps.
The supp a/c is a unit for when no engine is running.
