How many LRNSs do you guys have? We have five, but I'm new the plane and don't know if that's Gulfstream overkill or the norm.
If your talking about plotting inflight (I guess I call it plotting), we plot our lat log at each madatory reporting point while within the etops 90 min area of operations to verify that the magenta line is in the right place. As far as pre-flight plotting, we only do the ETP and EEP as the madatory reporting points are already charted. I only do Pac Rim stuff, so I'm not sure what Atlantic stuff is like. Also, we have GPS updating with our FMC's. No CPDLC yet but they say it's coming....
Three IRUs with GPS updating (VOR/DME or DME/DME if in Class I without the GPS). What exactly constitutes 5 systems on yours? That seems like a lot!
Three IRSs and two GPSs, so I guess it's not far off from you guys!
Can someone explain to the uninitiated what exactly a post position plot is, and what it accomplishes?
10 minutes after you cross an oceanic waypoint (such as 55N 030W), you take the lat/long the aircraft thinks it's at, and you plot that position on your chart. You do this to make sure that where the airplane thinks it is coincides with where it actually should be (i.e., your plotted position is on the course line you drew before you coasted out).This is a very good idea if your sole navigation sources are based on inertial reference (IRUs), but with GPS-equipped airplanes it's borderline unnecessary.
Thanks - I understand the first part, but not the second (blue). It seems that this does nothing to detect errors in the navigation system (i.e. the aircraft not being where it thinks it's at), but rather it's helpful to see if the route that the FMS is following differs from the route you had planned on paper (e.g. due to a misentered waypoint). As such, why is it less necessary to do these checks when you have a very accurate navigation source such as GPS? The check wouldn't reveal IRU problems in the first place.
So are you dissing my methods of entertaining myself when I'm out of reading material? Oh it's on... It's ON, son.![]()
I would pick random units of measurement and convert my times or fuel to some obscure thing. Temps in kelvin always got a raised eyebrow.
