CoffeeIcePapers
Well-Hung Member
Anyone flown one of these? 10GPH combined at 140 knots.
I have a hard time believing it will really burn that little amount of fuel.. So, two engines.. Single engine performance, but with redundancy. Overall looks like a freakin sweet little airplane. I could also see someone like ATP buying these.
Looks awesome - but $600k is a lot of moola. I would think ATP would pick up these and offer a significantly reduced multi program.
Have you looked at the price of a Seminole recently? With a G500 avionics suite, they're running 600K as well. Personally, having been in both a PA44 and the P2006T, I think the Tecnam is a nicer plane. Defiantly something that looks fun to fly. Also won't be crippled when 100LL goes away.
On a slightly different topic - ever notice how every ad for an aircraft with auto fuel STC claims they only run Avgas in it. So why bother getting the STC?
My Cherokee 140 also has an autogas STC, and I'm one of those people who never runs mogas in the aircraft as well. The primary problem is trying to find auto fuel that doesn't have ethanol in it; not very easy these days.
The Tecnam P2006T is a neat looking airplane, but if I was ever going to own a multiengine airplane, it would definitely be the Lockwood AirCam. Yeah, you'd have to build it first, but I seriously doubt there is a cheaper way to build multi time. Maybe a Cri-Cri?
Rotax engines are the key to using mogas. They were designed to run on gas with ethanol in it.
Believe me, it does. I got 4.5 gph out of the same engine on a single. ATP would definitely be wise to buy a bunch of these.
Just because they are designed to doesn't mean they are approved to. I know lots of airplane who use the Rotax who can't use ethanol laden Mogas, because the airframe isn't compatible with the ethanol. There's more to it than just the engine.
