I'm trying to educate myself on "see and avoid" and I found this:
14 CFR Part 91.113 (b) as follows:
When weather conditions permit, regardless of whether an operation is conducted under instrument flight rules or visual flight rules, vigilance shall be maintained by each person operating an aircraft so as to see and avoid other aircraft. When a rule of this section gives another aircraft the right-of-way, the pilot shall give way to that aircraft and may not pass over, under, or ahead of it unless well clear.
Digging into "right-of-way" I found this:
3.2.1 Right-of-way. The aircraft that has the right-of-way shall maintain its heading and speed.
3.2.2.1 An aircraft that is obliged by the following rules to keep out of the way of another shall avoid passing over, under or in front of the other, unless it passes well clear and takes into account the effect of aircraft wake turbulence.
3.2.2.2 Approaching head-on. When two aircraft are approaching head-on or approximately so and there is danger of collision, each shall alter its heading to the right.
3.2.2.3 Converging. When two aircraft are converging at approximately the same level, the aircraft that has the other on its right shall give way, except as follows: a) power-driven heavier-than-air aircraft shall give way to airships, gliders and balloons;
b) airships shall give way to gliders and balloons;
c) gliders shall give way to balloons; d) power-driven aircraft shall give way to aircraft which are seen to be towing other aircraft or objects.
Now I'm trying to figure who/what regulates/defines "well clear." Can someone give me a starting point to start looking?
Thanks!
Thanks!
