inigo88
Composite-lover
Re: DUN DUN DUNNN Super Secret helicopter used to capture OB
Army Times - Mission Helo was Secret Stealth Blackhawk
So let me get this straight. Since 1999-2000, the same squadron at Groom Lake that does base security in "slick" standard MH-60s by day, tested these babies by night? And then the guys from the 160th in Kentucky would rotate over to Nevada to train on them? (Flagrant unapologetic speculation on my part.) That's badass!
Edit: The article also lists a possible reason for the crash being "settling with power," which the Blackhawk is not normally susceptible to, but could conceivably be if they were at max gross, since the empty weight of the MH-60 is already higher and there would be the added weight of all the stealth modifications. I also read either in the same article or elsewhere that the radar-absorbent modifications to the glass do not play well with NVGs, so that could have been a factor (but not sure how accurate that is). Finally the Groom speculation was just that... Flagrant speculation (don't taze me bros!). They could have been at Creech or Nellis or TTR or elsewhere, but hypothetically being inside R-4808N could provide some additional privacy for that type of program.
