Aviator1988
so.... as i understand it, as long as i have an 80% pass rate and more than 10 recommended checkrides i can get my gold seal? is this correct?
I am nowhere near a copy of the FAR/AIM but that doesn't sound right.The 80% pass rate is actually a common misunderstanding. Specifically, you must have recommended at least 10 applicants, at least 8 of which must have passed. That's very different than an 80% pass rate.
You could sign off 32 people and have 24 of them fail. Even though your pass rate is only 25%, since 8 of those 32 passed, you'd be eligible for a gold seal certificate.
· Trained and recommended at least 10 applicants for certificates or ratings, and at least 80 percent of these applicants must have passed the flight test on their first attempt;
Because they were eligible back when they had an 8-2 record. To "lose" eligibility seems a bit bogus to me.
While you're right that you can provide a a selective record. I could have written in an extra 20 hrs of multi time in my logbook 6 months ago and been 100 pilots higher on a seniority list somewhere, but there are somethings that just need to be done honestly.
Let me ask as a follow up: Do you believe that a CFI that has a pass rate of 8-12 (40%) is really worthy of being distinguished differently than a flight instructor that has an 8-2 pass rate? I think the gold seal isn't really worth it's weight in gold (pun intended) but if somebody has gotten an 80% then they should be able to say that compared with a time builed that fudges their records and gets the same thing.
As you know, if a flight instructor really wants to distinguish themselves then Master CFI is the way to go....All just my $.02
Doesnt the FAA have a record of all the students you sent to take checkrides and what the results were?
.... having a Master CFI credential from NAFI automatically qualifies one for a gold seal certificate.
Not Anymore...
Just a fyi, In 2009 The FAA stated that the master instructor program was not in line with 8900.1 order towards getting a gold seal.
