B99 and C402 info.
ppragman
No pasa nada.
If anyone has any, I'd appreciate it, I could use some gouge and some info like systems, Vspeeds, weights, limits, etc. Anyhow, thanks.
-Pat
I don't have any info for you other than the 99's systems are as easy as pie. It will be a really simple aircraft for you to learn how to fly. The only issue that you may want to pay close attention to is single engine ops since you havent flown a lot of twin stuff lately..
99 - Dirt simple and tons of power. Don't even sweat it. I'd imagine it's much easier to fly than a 402. Oh, also: IT SUCKS, but congrats on the yob.
Never flown a B model 402, but the C model is a fluffy bunny to fly. Only issue is the engines; they can be fairly cantankerous when it's cold. No big deal. Start doing leg presses before training, by the way. :)
-Pat
i don't have any documentation to give you, but i have flown the 402B for the last 6 months. shoot me a PM with specific questions and i will get them answered.
Yeah Boris is being a doomer again. The 99 rocks!
The 402 (yes B model) requires a bit more finess to handle but its really a fun plane to fly. The hardest part about the 402 is getting those big cylinders started up when its stone cold. The trick is to prime the piss out of them. Like to the point gas is coming out. Mixture full rich, prime for a good 10 seconds and while holding down the primer start cranking. Works every time. Even at 5am in January in the artic north (wisonsin). Any other way and you're gonna kill the battery on two planes and wear out a battery cart on the third :laff:.
When the engines hot, start cranking and once it starts firing start tickling the primer. Otherwise you'll flood it.
Also- every single landing seems different and even after 500 landing you're proly gonna plop it in. Load heavy in the Aft and it greases down pretty smoothly.
As far the 99 goes. Let me scare myself a few times in one and I'll report back.
Sounds like the 402 is a lot like the chieftain in staring procedures and flying. More like 15 seconds on those cold mornings in PA-31.
99 is easy peasy to fly. I can't remember if you said if you are flying both aircraft simultaneously, but flying the 99 will feel like your on vacation compared to a high powered piston. Starting is SUPER easy regardless of cold or warm wx. Just watch those temps and N1.
How's the 99 compare to the T-tail King Airs with respect to systems and performance?
As I understand it, it's basically a 100 fuselage (except unpressurized), 100 engines, 90 systems, and Queen Air Wings, with a special hideous nose all its own. T-Tails are 200 and up (I think) and these are significantly more capable machines. Pressurized, faster, longer range. The 99 systems are DIRT simple and performance is significantly altered from the 100 due to the lack of pressurization. Unless you're using o2, which we never did, you're limited to 10,000ft. The 99 was intended for short route segments carrying lots of weight at reasonable speed. It's pretty good at that. When you start flying it for an hour plus, it can be a huge pain in the rear without an A/P (apparently some people get those...I think I'd hate it a lot less if I'd had one.) I'd probably hate it less if I hadn't flown the MU-2 first...hard to compete with (at least in my mind).
There are a few good things about the 99. It climbs like a raped ape. It is almost impossible to fly carelessly enough to get in trouble...it's like a giant baron with "go-lever" engines. It lands fairly well, or at least predictably (again, think baron). It's pretty hard to load out of CG if you're paying attention. It allows you to log multi-turbine PIC.
Haha. Are you gonna make good of those threats of changing my login name?
Here would be a good way to let the cat out of the bag...post something like this...
" I recently decided to further my career in the Air Force. Consequently, i headed to **CENSORED** to begin training. I was assigned to fly the **CENSORED** with a special mission of **CENSORED**. During my training event I met with rausda27, who was in my determination one of the most sincere, professional and dedicated pilots I have ever met. His skills far surpassed my own, and i was humbled to even be in the same building as he. He took me in the **CENSORED** simulator, which was the pinnacle of my already illustrious career. Now as I sit here in **CENSORED** , flying the ** CENSORED** all over this god forsaken %*&$!!, i think back fondly of my time spent with rausda27. "
