Hi!!
Im gonna go a little on the side of the issue here. I would state my intentions as an aswer, when he clears you for the option so thats said....
As I`ve experienced, alot of flight schools have either its own aiport, or an airport close by, were training are conducted. At these port`s its often congested with students alone, or with theire instructor`s doing pattern work.
Now, if there is alot of trafic in the pattern, and he cleares you for the option, keep in mind that it`s also a good source of information for the pilot behind you to know youre intentions, even though the controller has recognized your request, and given you "the infamous option".
- Let us say the pilot behind you practices on approaches with "a no flap setting" (you do your normal touch and go), he will fly the approach "alot" faster than you do. He`s just turned base to final.
Now suddenly you an your instructor finds out that he has a bugger on his shoe and says: "We`re gonna do a full stop, taxi back. I have to shine `em".
You call up the tower and the controller answer`s and says: " Taxi off at the nearest exit or whatever".
You find the nearest exit, doing youre thing, now the guy behind you calls the tower and says:" Yeaaaaah, well...we`re gonna go around. There`s this someone taxing on the runway".
Yes, you have the right to do it, but does it necessarily means that it is the smartest thing to do just because you got the right to do it?
Not the best example in the world, but that wassnt the point either. The point is: At busier airport, state your intentions regardless if you were cleared for the option, so the trafic surrounding you can plan theyre approaches a little better.
To you guy`s thats probably gonna come with: Well you should always have sorted out a plan of action so you can avoid this situation, or what if its an emergency and so on..Yes, of course! But its a two-way-run. Communication!!
On a airport were the trafic is light, and you know that this issnt going to screw someone over, sure! WILCO!?
Just reflect over the post..dont get "Chuck Norris" on me!!
