I need to stay in general topics, the other forums make me ill..
There are a few quasi-locally.. Mostly Nanchang Cj-6's which are cheaper to operate, go faster and burn less fuel.. They also cost more..
I'll be losing a good bit with the RV.. I'll go from 7gal/hour to 25+/hour.. I'll be going from 160kts to ~140kts.. I'll be going from tailwheel to trikey gear..
Don't really do much XC in the 6 anymore now that we are s family of 4. I usually just go up and have a good time and I'm thinking the Yak would be a good place to go..
I'm curious, what good does the helmet do? If you're going to plow into the ground at 130 knots you're plowing into the ground at 130 knots. Its not like a bicycle where you fall off and hit your head against the pavement
Provides a little more protection in the event of some kind of crash...lots of stuff to hit in a tight cockpit; panel, canopy, etc.
As was mentioned, protects against smacking the canopy while maneuvering, too.
....as well as just keeping the comms on your melon while maneuvering with some Gs. BFM/ACM, the David Clarks would be somewhere behind the ejection seat after being peeled off one's head.
Additionally, for bailing out, there are many things that can thump you in the head and black you out....
I see the point of wearing a helmet with an aircraft with hot seats, etc
But the CJ is made for little Chinese dudes. A bigger guy has a little trouble moving his nugget around with the helmet on, as a matter of fact, when I did wear a helmet, it was or nearly was in contact with the canopy (even with the seat adjusted). As far as the DCs sliding around, I've never really had a problem and they make a chin strap that keeps them where they need to be. Formation/BFM stuff can be a pain if you can't move your head and see what's happening IMHO. The Hooker harness is pretty good ....the tighter, the better sts.
The canopy doesn't just pop off, it slides back - the forward frame can catch your helmet if you're not slouching down. To continute with my rant... I'm not a big fan of the butt 'chutes that you sit on... rather sit on a cushion and have my back reserve conical that makes egress simple.
What's the story behind that midair?
Is that a formation with a wingman not maintaining deconfliction with his lead, or is that two non-participating aircraft that ended up in the same piece of sky at the same time? Looks like a very different flight path out of the RV, so if he was the wingman, something significant must have been happening.
The join-up was never briefed on the ground.. Never spoken about..
The guy in the RV-8 was good pilot but had no formation training..
The CJ pilot says he never heard the reports and had no idea what was going on..
Steve "had to have had more than 60 knots on BJ.".
I will never understand why people do this kind of stuff. Totally reckless and completely unprofessional. At least two pilots didn't die in the process.
Precisely why I don't fly formation with someone who doesn't know what they're doing and aren't trained. And without a pre-brief or at least some understood standards.
