Clipper5895h
Recently I had a chance to ride right seat in a K model Bonanza. When we were told by ATC to decent, the pilot proceeded to lower the RPM and increase the Manifold pressure, a technique I considered to be very odd when descending. I even noted a increase in airspeed because, in my opinion he was placing the propeller to a lesser drag, "feathered" condition. When we had put the aircraft away, I brought up his peculiar technique. He explained to me that Bonanzas (especially the V-tail) where notorious for picking up speed in a decent (the frontal drag and profile of a the aircraft are incredibly minimal, I believe it is equivalent to a 3 foot square board going through the air). He responded by saying that he had read an article in the Bonanza association magazine that claimed that this technique would actually prevent the aircraft from accelerating in a descent (essentially, you are in a downshift condition). With regards to propeller drag, there is two relative winds affecting the prop. First, the relative wind generated by the aircrafts forward momentum through the air, causing drag on the prop blade. Then, there's the relative wind that is working parallel and opposite to the actual propeller arc. What it boils down to is which one causes the most drag in a decent: 1) The forward relative wind striking essentially the wall of drag the propeller makes in a high RPM (low pitch)...Or 2) the relative wind that is striking the propeller parallel and opposite (in that casue, the most drag condition would be a lower RPM and Higher pitch). So, High or low?
