Well, the part that confuses me is when reverse sensing comes in to play.
The only thing doing reverse sensing is the pilots head. So long as you know it is a pilot head error, and not an instrument error, we can move on.
Next, reread what NJA posted. Reread it again.
Now, let's do an example:
1) The CDI is 2 dots to the left, pointed at heading 330, and the flag reading TO the station. Where are we in relation to our course? Where are we in relation to the station? What radial are we trying to be on?
To answer this, first we must know what is important. Here, below is a repost of the question with the relevant information bolded:
Let's look at what each bold item means, now, then answer our questions:
CDI is left - The CDI line is our course. If it is off to the left of us, then the course is off to our left. Thus, we are right of course.
Pointed at 330 -
It is important to distinguish between aircraft heading and VOR setting. This is what leads to pilots brains reversing things, but we will get back to that later. The heading the VOR is pointed at is the radial you wish to fly TO, or on (FROM).
Flag reading TO - Another important distinction must be made here. In this case, we are flying TO the
radial. You have likely heard that you are flying to the VOR. While this is also true, if you realize that you are also flying TO the radial it can help you better understand the instrument.
Ok, so what are the answers? Here we go,
If the course needle (CDI) is to our left, then our course is to our left. So, in this case, we are to the right of our course.
Hmm, maybe we want to know what radial we are on before we figure out where we are? Ok, so what radial are we trying to be on?
Recall above that I said it was important to realize that we are flying TO radial 330, if 330 is set into the VOR with the TO flag showing. So, if we are flying to it, there is a really good chance we are not on it at the same time. If we aren't on radial 330, but we are flying to radial 330, what radial are we on?
The answer is simply the reciprocal, or 330 - 180 = 150. We are on radial 150, flying to radial 330.
Well, now that we know what radial we are on, figuring out where we are in relationship to the VOR becomes easy. Draw a dot on a piece of paper, assume up is north, and draw a line that represents radial 150. You are somewhere on that line. In other words, we are south east of the VOR, on radial 150, flying to radial 350.
I told you I'd get back to reverse sensing, but only if you remember that it is a pilot head problem and not the instrument. In fact, when a pilot is experiencing reverse sensing the instruments are probably the only things in the airplane that aren't confused. But what the heck is it!?!
Take our example from above, flying to radial 330 and on radial 150. Our compass is pointed at heading 330, since we are trying to fly to that radial. Now, if we were to continue flying heading 330, but for some odd reason turn the VOR dial to 150, then we would be experiencing an instrument acting in reverse.
In this situation, if the course needle deflected left, and we turned left to chase it, it would go left faster. This is because the course is to our right now because we have the instrument upside down. Well, not literally upside down, but it is pointed to the exact opposite heading we are trying to fly.
Ok, hopefully we are on the same page with what this is. So, how do we fix it? Simple! Make sure your heading on your compass (or DG assuming you made sure these match) make sense.
For instance, if your VOR is set to 250, you might have a heading of 225, 247, 262, 273, etc then your VOR and heading make sense. Your situational awareness is in tack. Conversely, if you see 043, 057, 080, 092, etc on that compass then you know something is screwy and if you try to read the VOR like this it will be backwards. Or, if it is easier to remember, just check accidentally turned the VOR upside down.
Hope that helps and I agree with NJA. Rule of thumbs are great, but when you are trying to teach this stuff they provide little help without a solid understanding. It's time to buckle down and really figure it out so you can ace that CFI ride. Good luck.
