Your thread title and your post are contradictory. The Thielert I would run fast and far from. The AE300, I would wait and see. If it addresses the issues of the Thielert (namely, reliability, parts cost, and that darn gearbox) then it is a much better fit for the airframe than the Lycoming.Happy New Year to everyone!:beer::king: Spent my time watching Twilight Zone marathon episodes, so life is good.
Jury is still out I suppose on the transition of DA42 from the Thielerts. Just wondering which would be compartively speaking the better buy?
A valid argument. However, internet debates aside (over square, lean of peak, etc) the red and blue knobs on smaller engines (for example, Duchess and Seminole) are not exactly rocket science. Both forward for takeoff and landing, blue ones back a bit in climb, red ones back a bit in cruise. Now getting into something like a 414/421 will be a bit of a learning curve regarding the extra levers, however not much more so than someone stepping up from a Duchess.My only problem with the diesels is that the twinstar is mostly being used as a trainer. In that case a student who has gotten used to the two lever setup might hop into a "conventional" twin and not know what to do with those extra knobs.
. . .and that I heard as well. It's kinda like a "set & forget" system with the FADEC system, so manifold pressure concern issues are gone. Just wondering if there's more. I don't specifically perceive that as a "negative" but some might believe so should transitioning to the extra knob twins be in the future.My only problem with the diesels is that the twinstar is mostly being used as a trainer. In that case a student who has gotten used to the two lever setup might hop into a "conventional" twin and not know what to do with those extra knobs.
I was misled by the inclusion of the word Thielert in your original post. From what I've heard (all second-hand, as I only flew the Thielert ones) the Lycoming is kind of a poor fit for the DA42 for several reasons. The biggest is the Lycs are thirsty, thirsty, thirsty compared to the Thielerts, and range/payload are very limited. A further problem with payload is that the rear edge of the CG envelope was moved forward due to the higher power on the Lycs resulting in Vmc issues. There is an STC for extra ballast up front that solves the CG issue, but that's extra dead weight that cuts into fuel/payload. Despite the higher horsepower ratings, I've heard anecdotally that the Lyc version performs slightly worse on one engine because the "feathered" prop turns over one stroke at a time because it's designed for a higher-compression diesel engine. On the other hand, for multiengine training the Lycs might be a better bet because all those peculiarities will make transitioning to a practical multiengine airplane (Twin Cessna, Baron, Navajo) easier.OK, now I'm confused why you're confused, but I'll elaborate further. The new Diamond DA42 comes with two options. They are available with either the Austro Engines AE300 turbo-diesel, or the Lycoming IO-360 avgas engine. As you might expect, the Lycoming probably has more power while the turbo-diesel weighs more but has a lower fuel burn and Jet A availability (price concerns). Just wondering what other factors might be considered?
Yeah, well, some of the ones you gave remedial training to might also not have been the brightest bulbs to start out with...just sayin'.This is an actual problem. I have had to give remedial training to several people that did their training on the Diesel DA42 and had no idea what to do with all the extra levers...
With that being said, once the place I worked for switched to the Lycoming DA42, most of the problems went away.
DA42 requires flipping a switch to feather-not really any different from yanking back on the blue lever. It is NOT auto-feather.I agree. I think some training is necessary because given that engine failure happens close to the ground, it would be a bad time to try and catch up on the learning curve. Interesting to me that you can do your multi in a Skymaster and you are given a centerline thrust limitation; whereas, you can fly only a FADEC equipped aircraft and not have any limitation imposed.
To the OP:
If you're seriously looking at a DA42, I still remember a lot about systems and flying characteristics. Also lurker cjreed172 has a gob of time in the Lycoming version and if you PM him he might answer. Personally I think the Austro engine would be a better buy especially if one were planning on using the aircraft as a personal aircraft-the Lycoming one seems like a good trainer but my impression is that the range and payload concerns could really handicap it as a personal aircraft. However, the Austro is at this point still a very very unproven engine so I'd wait it out.
Or, if you really have twin lust, you could get one heck of a used twin for what a new DA42 costs.
For the life of me I cannot figure out why Thielert and Austro think they need to spin a diesel fast and have reduction gears. Are these engineers on crack?
No more so than a Duchess or Screaminole.I have about 1.4 in the Twin Scare so take my point of view with a boulder of salt, however, there are few things scarier than a DA42 with three normal sized people in it with one throttle back at idle at 100'AGL. The thing is a dog!
Also, lighter engine.To get power out of a lower displacemet (more fuel efficent) engine you have to run it at a higher RPM.
