Franklin 220 HP 6A-350 engine
Airmann
Anyone have opinions on the Franklin 220 hp engine being placed in the Cessna 175 or Cessna 172? Do they really have the 1400 FPM climb/ fuel burn/ cruise speed of 150 +, and take off roll of 300ft? Is it a plane worth buying, having that engine in it, or having it put in a plane? Are parts readily available? Any info and/or opinions are appreciated.
Is this engine a PZL? Otherwise, the Franklin is a fine engine but it is an orphan.
I've never heard of it installed in a 172 but I've flown behind it in a 170 and 185.
If it’s running right the numbers can be for real I fly a 1967 172H with a Franklin 220. For the most part it is equal to or out performs a 182. The Franklin is a great engine, but misunderstood buy most that repair them, compound that with scarce to nonexistent parts, make a Franklin 220 nearly a museum piece. Unless you’re a fearless mechanic, machinist or know one and have experience in all facets of engine repair you could be buying a huge headache. On the other hand, the Franklin turns a 172 into a fun responsive and safe airplane, an airplane that is off the ground when most 172 are just starting to indicating airspeed, an aircraft that can jump back off the ground and climb out when blown off the runway. This IS the airplane that Cessna should have built, a friend of mine has a 172XP with 210 HP mod. My plane makes him grin. If you end up with it make sure that it has a JPI engine analyzer or the equivalent, it eliminates guess work of engine management. Never run Mogas, Franklins have a 10.5:1 CR.
and are Easley damaged that way. In closing, it’s a real shame that Franklin engines are out of production.
Oh, ya and as far a fuel burn and speed, I generaly cruse @ 70% 6500 msl to 9500 msl true airspeed is about 152 MPH and fuel burn is 10 gph average, two hour flight = 20 gal.
