Logging second in command count as Total?
Pilot86
I am always in need of building more flight time to get my commercial and I would like to split flight cost with another pilot. Say a 2 hour flight, and he flies one leg and I fly it back and vise-versa. But the time I'm not acting as pilot in command, can I still log the time as he's flying for total time as second in command?
Putting it in my logbook like this as an example..
Pilot in command 1 Second in command 1 Total time 2
Can I build flight time that way?
Assuming since you're a pre-commercial pilot that you're flying an aircraft certificated as a single pilot aircraft, and not operated under Part 135 IFR, the answer is no (assuming you're flying something like a PA28 or C172).
The only way to "build time" in the manner you described is by using the "safety pilot" clause. Essentially, the pilot in the left seat is wearing a view limited device, and logging simulated instrument time, and during this time, you may, as the pilot in the right seat who is responsible for looking outside the aircraft, log that time as either PIC or SIC, provided you are rated in category and class (i.e. Airplane Single Engine Land). If you search this forum, you will find many threads related to this.
NO!!!!!!!!
Pick up a FAR/AIM for crying out loud.
NO!!!!!!!!
You mean you're actually expecting someone (let alone someone who wants to be a commercial pilot) asking a logging flight time question to read 61.51, the "universal rule of logging flight time?"
Agree.
Use the search function here, people. That, or read 14 CFR 61 as Mark said.
I know right? What was I thinking?
Easy! Lets not forget this is a site for learning how to be a professional pilot.
Instead of ridiculing or saying "use teh search function" and causing apprehension to ask a more important question next time, simply point him in the right direction and end it there.
Just because many of us have seen this discussion many times on here, with a post count sub 10, he most likely has not. No reason to not treat this thread with the same level of respect and courtesy as the previous one on this topic. :rawk:
Welcome to the site.
If he's to the point of building time for his commercial, the day has come and gone for him to know where to find regulatory information. If he can't handle looking something up in the FARs or AIM, he will have problems down the road.
Not arguing with that. Simply saying we can help him learn how to use the FAR/AIM without the extra comments.
Everyone single question on here could be answered by picking up a book on aviation be it regulatory, technical, procedural or simple general interest. Just because this discussion comes up more often than say, regs for 135 maintenance, aircraft annual or GPS in lieu of DME (all posts in either the technical or CFI forums) doesnt mean it isn't worthy of a respectful response. http://forums.jetcareers.com/technical-talk/115274-135-maintence.html
I'd agree, but that doesn't mean he doesn't "deserve" an answer.
Exactly!
You are absolutely right. 86, no excuse but this is an old conversation, so please accept my apologies.
85% of all logging flight time questions can be answered by looking at only one reg - 61.51, the one that deals with logbooks. Another 10% can be answered by looking at 61.51 and another reg that 61.51 sends you to. The extra 5% is a fudge factor where the regs and their official interpretations need a bit of explanation.
Take your question, for example.
61.51(f) starts with
Logging second-in-command flight time. A person may log second-in-command time only for that flight time during which that person:
Then comes the list (I like to think of them as "boxes") of the entire universe of situations in which one may log SIC.
Take a look - if your example fits in one of the SIC boxes, you may log it. If it doesn't you may not.
Where do you think your question might fit in?
Please don't do this to yourself-walking into an interview with a logbook containing PA-44 (or similar) SIC time is an express ticket home.
Listen to these other guys, they are so very right.
I try to encourage people to exercise something called personal initiative; something that someone who is post-PPL and working on their Commercial should probably know where to find the answer to a question like this. There's a fine line between helping someone out and spoon-feeding them, the latter of which many on this site seem to give and users seem to expect, often.
If you can legitimately log SIC time (per 61.51), then you can also count it as total time.
As for legitimately logging SIC time, you must be a required flight crewmember. If you're just sitting in the right seat of a C182 (certificated as a single-pilot aircraft) while the other pilot flies the leg, the FAA views you as as passenger. On the other hand, if you're acting as the safety pilot while the other pilot is under the hood, then you become a required crewmember. Likewise, if you're sitting in the right seat of an aircraft that requires a second crewmember either by aircraft type certificate or the regulations under which the flight is conducted, you are also a required flight crewmember and may log the time. Clear as mud?
Thank you for the comments, Im just a private not even intrument rated. appreciate the support. could I pick up a book yes but I enjoy listening to and learning from other pilots especially in the black and gray areas.
If you ever get into a jam where you get penalized from the FAA or authority, I guess they can just throw the FAR/AIM book at you when you ask a question and say "READ IT YOU RETARD!!!!"
Thanks guys.
Your welcome!
You need to pick up the book, because believe it or not, not all of this gee whiz information on the forums is correct.
Thanks guys.
The point of knowing the FAR's and utilizing the FAR/AIM is so you never end up being "penalized" by FAA. It's not going to save your butt AFTER you bust the reg's.
Food for thought, two rated pilots (category and class) can log PIC, only one can "act" as PIC. Find a reference in the FAR's and bring it back to the forums so you can contribute as well!
back in my private training I would always have some questions for my instructor regarding FARs. His response was:
"Where's your FAR/AIM"
I'd get it out,
"OK now this question is about logging time, open the book look at the glossary and find me the answer"
I'm not a FAR AIM nerd now but I very often have some technicality questions and the book seems more manageable now. Especially when you remember that something is in the AIM and not in the FAR and you're like woohoo time saved!
SIC can only be logged in aircraft that require a SIC by the type certificate or by a company's FAA approved OPS spec. You could log it as PIC and total if you wanted to act as a safety pilot.
