The Gardener
Terrafirma Phobic
Dang when was that ?
There was one in Montana a few years back. The diver broke his ankle and everybody in the plane died.
We all share the sky. Some have motors, some don't. :beer:
And you have to ask yourself, "why is that?" Considering jump planes are required to be communicating with ATC, either approach or center is going to have a 2 minute call and jumpers out call. Additionally, most all pilots I know make at least two calls on CTAF, warning call and jumpers away call PLUS a call or two that jumpers are in the air.I just worry about running into a jumper at my local field.
Surface to 13000 at the intersection of three instrument approaches is NOT a good (or even an appropriate!) place for a drop zone.
...well aware. And to be fair, our guys are pretty good about "two minutes" "one minute" and "jumpers away". I worry about it (read on...)And you have to ask yourself, "why is that?" Considering jump planes are required to be communicating with ATC, either approach or center is going to have a 2 minute call and jumpers out call. Additionally, most all pilots I know make at least two calls on CTAF, warning call and jumpers away call PLUS a call or two that jumpers are in the air.
There is a difference between vigilence and complacency, awareness and ignorance you know.
I've had the nasty experience of the "jumpers away" call being made while I'm established on one of said approaches and in the vicinity of the drop zone. I've also heard a few "turn to such and such immediately, parachute jumpers 12 o'clock 3 miles, your altitude" calls on frequency. Yeah, the system is working and all, but it could work a little better.Really? Again, I think you assume too much that you own that airspace. Do you also think gliders should not fly there because they may not be communicating on a freq. with you; or any aircraft not on a radio for that matter? What about transient hot air balloons?
I think your view needs to be explained more fully to understand why you think the way you do....please, help me understand this mentality.
It's BS that just because there's a NOTAM, there will be less airport traffic.
The NOTAM is simply there to give a heads up to people arriving/ departing. Planes and jumpers can easily co-exist at the same GA airport, just with a little communication and some better visual lookout.
Nerd alert!![]()
No do not really scare me but I keep my distance from airports that have jumping going on. Yolo, Lodi and a few others are well known. I've had to pick up PAX at Yolo and was bitched out for picking the wrong traffic pattern (the side with the DZ). This was not indicated on Jepp charts. I don't like being bitched out and of course the information was not available to me on an IFR flight plan using IFR charts.
I would agree that jumpers and pilots dont "get" each other. This is the big problem.
On a student solo cross-country a long time ago I had flight following with Travis RAPCON and was passing Yolo. Being a student pilot I had no exposure to jumper ops, and said I was unfamiliar with the DZ when asked. They preceded to vector me like 5 miles away from the airport until I cancelled flight following.
Knowing now about how to listen to CTAF/approach and maintain situational awareness of when jumpers are in the air, it really seemed like a huge overreaction.
For that reason I can sympathize with why some GA pilots would avoid drop zones, but I think it's curable through better education on how the process actually works.
