Garmin 296
Zero1Niner
Just got a 296, and flew with it for the first time last night. Amazing.
One thing is driving me nuts, and I am not sure exactly how to correct it without completely disabling the warnings, and that is too many airspace notifications when the airspace is still miles away. 'Airspace Ahead 10 minutes' messages all night. Is there a way to lower the number to 1 minute or some other modification to reduce the number of unnecessary notifications?
Thanks
Thanks
If I remember correctly, you'll need to go to the main menu section. Press the menu button twice, then scroll down to the settings tab. Then, scroll right until you get to the area where you can control all the alerts. I personally nuked all the alerts because I used it for IFR situational awareness and wx.
and if it is not there, the menu section should have a settings tab called alarms. There should be airspace alarms under that section which you can toggle on and off.
I KNOW I AM IN THE FRIGGEN AIRSPACE!!! YOU'VE TOLD ME TWENTY TIMES IN THE LAST TEN MINUTES!!!!!
That is my general demeanor with airspace alerts on ANY Garmin product, all of which I've used!
We've got one installed in our 152. I find the advisories quite annoying so I've turned it off completely. In the LA basin it freaks out every time you change direction and just becomes useless.
