azaviator08
Just wondering how everyone teaches compass turns.
All timed. I have my students break it down. 2 minutes for 360, 1 min for 180, 30 seconds for 90 and 15 seconds for 45. At the very basic 3 degrees/second, or 10 degrees in 3 seconds.Just wondering how everyone teaches compass turns.
I don't. Doing timed turns compass errors are not really a consideration. It may not be very accurate but then neither are doing compass turns.For compass turns - I know you UNOS by lattitude. But you also need to use your normal roll out lead. What do you use for this?
I think I must be confused by the question.For compass turns - I know you UNOS by lattitude. But you also need to use your normal roll out lead. What do you use for this?
For a major heading change I use compass turns to get close. When you roll out of the compass turn, check the heading. Then make a timed turn to get right on-say you're 5 degrees off, that's roughly 2 seconds at standard rate. Seems to work alright for me.
In a real world event where you are executing an instrument approach, keeping up with the time while turning is an added task. I find using the approximate lead and lag works really fine without mentally keeping track of the seconds as I talk with ATC and/or make small corrective heading changes.I don't. Doing timed turns compass errors are not really a consideration. It may not be very accurate but then neither are doing compass turns.
To each their own. when shooting an approach there is usually a stop watch running anyway. To me PERSONALLY it seems easier to do timed turns than remember how compass errors work on the spot.In a real world event where you are executing an instrument approach, keeping up with the time while turning is an added task. I find using the approximate lead and lag works really fine without mentally keeping track of the seconds as I talk with ATC and/or make small corrective heading changes.
A combination of the skill of using time when appropriate and lead/lag when appropriate, and both as backup, is the intent of teaching and learning this basic skill.
That's because you haven't learned to use the lead/lag method.To me PERSONALLY it seems easier to do timed turns than remember how compass errors work on the spot.
No, I can do it. I'll blame primacy though. I've always done timed turns and they just work better for me.That's because you haven't learned to use the lead/lag method.
I can't tell you how many GA airplanes I have been in where the clock doesn't work.when shooting an approach there is usually a stop watch running anyway.
If the clock doesn't work you shouldn't be going IFR anyway...I can't tell you how many GA airplanes I have been in where the clock doesn't work.
Or the start/stop button sticks and the student becomes obsessed with starting the time while he is overshooting a turn.
That's a lot of blame. Unfortunately it's accurate. The emphasis seems to change periodically. When I did my instrument training, the focus was on compass turns and they were almost second nature. Timed turns were more difficult to me and I never really learned them until I needed to for my CFI-I, but which time the emphasis changed.No, I can do it. I'll blame primacy though.
AgreedThat's a lot of blame. Unfortunately it's accurate. The emphasis seems to change periodically. When I did my instrument training, the focus was on compass turns and they were almost second nature. Timed turns were more difficult to me and I never really learned them until I needed to for my CFI-I, but which time the emphasis changed.
Both methods have their issues but they really should be given equal, um, time, when being taught.
