ryan1234
Desensitized Member
I read the M14P is considerably less expensive to maintain and operate than the 540.
It is... most of the work you could do yourself with no problem - they were designed to be taken apart, put back together, and operate out of fields with little in the of facilities. It may be slightly more MX... but not quite as expensive...
Plus who can resist the sound and smell of the radial?
With the AEIO-360, which is a great engine, I think the prop would need overhaul every 200hrs or so from competition use (not sure on that, but that's what I've heard) - where with the M&T composite for the M14P it wouldn't be so much.
