Okie_Pilot
Pitts Builder
So we're at a deciding point on what to do with our Mooney. We bought the nice little 1963 Mooney M20C from a friend in Alabama for relatively cheap. So we made a trip down to Alabama and got everything checked out on it and flew it back home to Oklahoma.
After calling Mr. Wheat at Mooney, which is the Mooney guru who helped Mr. Mooney design the airplanes to begin with. We did a check and found rust in the pilot side tubing which is due to the Mooney factory screwing into the tubing to hold the sheet metal and/or other parts on. When the airplane would fly IFR or be rained on, the water would get on the screws and run down them, inside the tubing and then eventually rusted the inside of the tubing. They used standoff posts, or clamps on the passenger side instead of screwing into the tubing, so that side is rust free. We have the tubing replacement that came straight from Mooney that we're about to put in. This is a common problem with this version of Mooneys.
Now we're at a deciding point:
1: Continue rebuilding the Mooney
or
2: Try to sell the parts and get our money back to finish building our Pitts S1 project.
The plane and engine only have about 1100 hours on them, and it's been hangared it's entire life. The fuselage is clean and straight, and about down to the bare minimum a fuselage can get. We spent over $5k getting the new hub and prop overhauled and painted and is perfect. We just removed the engine to work on the fuselage better. It's a Lycoming O-360 with a new carb, mags, fuel pump, and oil lines. (Remember, we flew it from Alabama to Oklahoma). However, truly the last time the plane flew before that was in 1992.
When we bought the plane, I was envisioning upgrading the interior and avionics and off we go into the wild blue yonder. However, no one can foresee the future especially when it comes to aviation. I personally would like to try to recoup some of our investment back out of it and transfer the funds to getting the Pitts S1 project up and going.
Do you guys know of anybody looking for any Mooney parts? A spare fuselage, or a perfect wing with the entire landing gear with new tires, or a low time engine with new accessories? Nothing is missing, we have everything. What do you guys think?
If not, here's some interesting pictures of a deconstructed Mooney:
or
