popaviator Well-Known Member Aug 15, 2010 #1 I'm curious what pressure level turns on the hobbs meter in a CE172? I looked through the POH and couldn't seem to find the answer.
ppragman No pasa nada. Aug 15, 2010 #2 popaviator said: I'm curious what pressure level turns on the hobbs meter in a CE172? I looked through the POH and couldn't seem to find the answer. Click to expand... Hobbs is after market, that's why, you should check the maintenance manual for the hobbs switch.
popaviator Well-Known Member Aug 15, 2010 #3 ppragman said: Hobbs is after market, that's why, you should check the maintenance manual for the hobbs switch. Click to expand... Ah! Ok thanks! :rawk:
