popaviator
I have been doing touch and goes with my student and have had some rough landings to say the least.
irate: I was curious how much force a 172 can withstand before the shock struts collapse or become damaged.
x2The problem with the 172 gear is that the nose gear can't take much punishment, but the mains are fine.
For some reason the 172 with students really lends itself to landing flat. I do recall it landing waaaay better if loaded to max gross with people in the back seats.
That is true. I also think the Cessna-recommended 65 is too fast for entering the flare, at least at light weights. Short fields are a lot easier if you come into the flare at about 50...I find that tends to be an airspeed problem. If my students come in too fast, they tend to land flat instead of being patient and letting the airspeed bleed off.
Depending on the length of the runway, you may or may not still be over pavement by the time you land...but yeah..It's more fundamentally a failure to recognize the proper pitch attitude for landing. Once that picture is firmly ingrained, you can come in at full cruise speed and still land nose high.
Takes about 7,000 feet at 120 knots, zero flaps.![]()
Funny yet tragic story:
I've personally seen a new-hire CFI from a "Mill" forced into a go-around on a 7400 foot runway in a 172.
The second attempt had him hard on the breaks for the last turnoff.
"Something is wrong with that plane"
"Nope"
The older 182s, with the manual flaps, can land softly everytime....you can use that flap handle like a helicopter's collective.
