Radio Communication
VA Aviator
I am trying to learn proper radio procudures:
I normally say:
Me:ABC Ground Skyhawk 3TPFA at FBO ready for taxi to active
Them: 3TPFA ABC Ground taxi via A and B to 23R.
Me: taxi via A and B to 23R 3TPFA
in general is it correct to say your call sign at the end or when you give ground tower approach a reply do you say your call sign and then repeat instructions given.
Me:ABC Ground, Skyhawk 3TPFA, at FBO (which one? say the name) ready for taxi to Runway XX with information XX
Go to my website linked below, click on Download files and read the file called "KTLH Radio Communications for local flight"
I normally try make all comms with my callsign first, followed by readback/whatever else.
Doesn't really make sense to state "taxi to the active" or "taxi to runway xx" (unless you have a specific runway request) as ATC assumes you want to taxi to a runway to depart.
The key is to be clear and concise; while it may not be important at a small, quiet class D, it will be when you begin to go into larger airports.
"XXXX Ground, Cessna 12345 at Signature, Taxi with Delta"
Normally you will read back an instruction of ATC with your tail number at the end (although often people do it both ways and it is a matter of semantics).
ATC won't know if a pilot is at the controls wanting to take off or if a mechanic needs to reposition the aircraft for MX. If you skip the "taxi to xx" part at our airport, we have controllers that as "what do you want to do?" or "say intentions".
I typically go with: "ready to taxi with xxx (atis) for a xxx-bound departure"
I could see where that happens, but it must be a local thing. If we need to go out for an MX runup then you always specify you'd like to head to the blast fence. Never had that problem at any other airport I've been to.
Ive heard some people say their call sign at the beginning and some say it at the end even if they say the same thing I don't want to start a bad habit.
:yeahthat:
A controller that isn't stupid/training/being a deliberate jerk will know. Sometimes I don't even get a "request taxi" but they check on with the atis, type aircraft, destination and VFR cruising altitude. It's pretty clear they want to taxi and obtain flight following.
Brevity can go too far. Especially with inbound VFR aircraft that check on "Tower, N12345 is 8 miles north with Atis." Well, in that situation the options are a little more open. Touch and Go? Stop and Go? Full Stop? Taxi back or taxi to parking? Airspace transition? Taking photos of my mom's house? etc.
But on initial call for taxi, the brevity is more easily interpreted. I'd say it's perfectly fine to shorten it up, or lengthen it as much as you deem necessary to get the needed information out there. And of course, in Gajre's case, maybe custom tailor your technique to accommodate your local controller's sassiness.
And as far as reading back the callsign at the beginning or the end, it doesn't matter as long as it's in there and as long as it's proper. No callsign, callsigns without "november" or "type aircraft + at least 3 digits of the tail number" are improper for ATC use and can get us in trouble if we don't demand a more complete callsign during readback. Believe it or not, I've read error reports where controllers "lost" separation because one of the aircraft they were talking too responded with the correct instruction, but didn't use their callsign or enough of their callsign. It's ridiculous. In before pilots jump me for ATC not using proper callsigns all the time, that IS wrong as well. Two wrongs.....
I do it completely backwards from you...
"Air Carrier 207 fly heading 140"
"Fly heading 140 Air Carrier 207"
My logic is, the controller addresses me with the callsign first, and I'll put it last to differentiate myself from what he's saying.
At the local small town airport, where we only have one runway, the folks up in the cab have become awfully strict about reading back the runway assignment. If you don't say "Runway 26 via golf, alpha, Cessna 12345" expect to be asked to hear it again. :dunno: It does make sense if you've got more than one active runway, I guess.
I do that many times as well. I also mix it up to make sure that they are listening to words, not just patterns.
Pilot: xxx ground, Cessna 12345, ready to taxi from Signature with information Bravo, request runway 10.
Ground: Cessna 12345, xxx ground, taxi to runway 10 via alpha and charlie.
Pilot: cessna 12345, taxi to runway 10 via alpha and charlie.
