So I'm getting checked out at a Skydive place and they have some info that we are supposed to read before we are checkout out to fly and one of the items is about descents...
It says that the plane will not come down any faster in turning descent (Call it 45 degrees) than it would in a wings level decent. Now, I had some problems with this statement as it seems that the plane would absolutely come down faster in a turning decent than it would in a wings level descent.
So which is going to make the airplane come down faster (i.e. greater negative VSI reading) a 45 banked descent or a wings level descent?
To give you more info the on the plane (which I guess shouldn't matter),it is a twin otter and we do our descents at 140 KIAS to get down ASAP. My thought is that the plane will descend faster in a 140 KIAS decent with 45 degrees bank because for a given airspeed there is a "X" amount of lift, of which in a wings level decent the vertical component of lift is greater than it would be in turn where the some of the VCL becomes a HCL for the turn; Therefore less lift in the turn which would lead to higher descent rate.
Anyway, I could be way off and making this way more simplistic than it should be but what's the right answer?
Thanks in advance.
Thanks in advance.
