Can you damage a prop in-flight?
Possibly, but props are so darn strong I think you'd be really, really unlikely to damage a previously-undamaged one just by overspeeding it. Personally, I think that you'd have stuff like magnetos, alternators, and engine internals get damaged first. Now, if you have a crack in the blade or you get some weird resonance at the overspeed RPM, that MIGHT do it.
Engine problems too, but the thread is addressing props.
I don't have any fancy equations to back up what I said, I'm just regurgitating what John Eckalbar said in the Propeller chapter of his book, "Flying high performance singles and twins". He has plenty of those equations. Me, not so much.
It fly.
Make loud noise.
In closing, I would recommend that as an active CFI you gain more knowledge on these subjects so that you can properly teach your students.
Yes, I agree. Please understand that I'm not trying to teach something I don't know about, but trying to participate in a discussion with people who do. Which would, I believe, help me to gain more knowledge on these subjects so that I can properly teach my students.
Go back to internal combustion engine school. The oil pressure is not "going to redline" because you left the prop forward and changed "torque resistance." Oil pressure is dictated by the speed at which the oil pump is driven (which in our case, is engine RPM), the thickness of the oil (both the actual viscosity rating of the oil and the temperature it is at) and the resistance to flow within the engine (the size of galleries, orifices, bearing clearance, etc). Also keep in mind that many different engines read oil pressure at different places in the engine, which can have an effect on the number that the gauge reads.
Hehe. I don't recall ever learning about galleries and bearing clearances. But that makes a hell of a lot of sense if I think about it with that in mind. The oil pressure wouldn't increase from the rpm decreasing.
Remember that the prop is an airfoil, and during flight, will be kept in rotation by a combination of engine power and aerodynamic forces. Below a certain power setting (both manifold pressure and RPM) for a certain airspeed the prop is actually driving the engine, causing negative thrust (and this is why it's imperative to feather a dead engine's prop). As you increase prop RPM at low manifold pressure (say on short final), you are INCREASING resistance (if you want to think of it that way) on the engine by allowing the prop to create more drag, which is why the airplane slows down (assume manifold pressure and aircraft pitch and configuration are kept constant).
Right, that I understand but maybe I'm not making an obvious connection to the scenario that was proposed. I understood the scenario to be where you were already cruising at speeds in excess of 100 knots with a lower RPM setting (say 2100).
Before I continue I'd like to try and clarify what I meant by "torque resistance". I was referring to the resistance to rotation (drag) the propeller airfoil induces by creating lift as it rotates at different blade angles, but I couldn't think of another phrase to use. Let me take another stab at it and maybe you can enlighten me a little:
An engine running at 25" MP and 2500 RPM is producing a specific amount of power (as is indicated by the MP even though its actually measuring a vacuum) to spin the propellers at a low angle of attack (relatively less drag on the propeller airfoil). If you stay straight and level at 25" MP and change the RPM to 2100, the propellers go to a higher angle of attack to allow the RPM to decrease (more drag for the propellers to rotate against). So now the same 25" of MP is spinning the propeller at a lower RPM.
Isn't it the same as during an engine run-up when you pull the prop lever back to check the governor and the engine bogs down for a second and the MP increases? So basically, doesn't reducing RPM without reducing the MP make it harder for the engine to spin the propeller?
Now please understand I'm not saying that this means I think the oversquared myth is true. I've seen the cruise settings in a POH and can see that it won't destroy your engine. However, the way I currently understand it, there should be some effect on how hard the engine has to work. Then using the same line of thought, I supposed that the inverse could be true.
Without adjusting the throttle from 25" MP cruise and changing the RPM from 2100 to 2500+, wouldn't the engine find itself momentarily having an easier time spinning the prop (less resistance to rotation)? Of course the high airspeed would also be driving the propeller and causing negative thrust until the forces balanced out. Am I completely misunderstanding something?
BTW, I'm really enjoying the chance to talk some of this stuff out. Most of my friends and family just want to change the subject. :D
To answer your question, you're not going to hurt the prop. It is possible to hurt the engine with certain MP/RPM combinations, and those vary based on the airframe/engine/prop combination.
The scenarios you describe can't hurt the prop (unless as someone mentioned you manage to overspeed it).
Just a place to hang this:
The Safety Board concluded that failure of the blade from NlllGC was caused by high cycle fatigue stresses induced by a resonant vibration of the propeller. This conclusion is further supported by the results of previous testing performed on another M-74 Sensenich propeller cut to 68 inches in diameter. That testing consisted of a comprehensive, in-flight vibration survey conducted on a homebuilt Thorp T-18 airplane powered by a 0-320 series Lycoming engine. The experiments showed that when the propeller operated above 2,500 rpm, the actual vibratory stresses at a point located 17 inches from the tip of the blade exceeded the allowable level by more than 2,000 psi.
Due to the complexity of a propeller design and the susceptibility of a propeller to failure when operated at speeds that excite resonance, propeller manufacturers ordinarily determine the vibration characteristics for each of their propeller designs. When the propeller diameter is changed, the propeller's vibration characteristics are also changed. Type Certificate (TC) P-886, issued for the original M-74DM Sensenich propeller, specifies a minimum propeller diameter of 72 inches for both the Lycoming 0-320 series and Lycoming 0-290-0, -D2, and -D2B. Furthermore, the TC states that from a vibration standpoint "no reduction below the minimum diameter listed is permissible."
The failure of the propeller was 'catastrophic"; that is, the service stresses were high and the fracture occurred in a relatively short time. Because the diameter of the propeller was changed, the propeller vibrated during normal engine operation at resonant frequencies that induced stresses far exceeding its design fatigue limit. With such a mode of failure, it is not feasible to predict when failure will occur: thus, it is not possible to determine, with confidence, an interval for inspection that could detect fatigue cracking before the complete failure would occur.
Full report:
Full report:
Ok, allow me to rephrase. While operating within the limits the manufacturer prescribes, hurting the prop is EXTREMELY unlikely. The case here, the prop was operated outside its design parameters, and it failed. No surprises there.
But is there still a concern for having the throttle advanced with the prop lever at low rpm? Am I incorrect in thinking that has to be bad? Or is it just that on a smaller scale it won't affect the engine?
You'd have to go to the engine manufacturer's engine operating guide to know how much of a split there can be; in the Lycoming IO/O-360 lines, the RPM can be quite a bit higher than the MP. If you exceed that, I suspect the problem is potential detonation, although resonance is a possibility, too. The only Continental operating guide that I looked at had a much smaller permissible gap between MP and RPM.
I have read of nothing that indicates there is a problem advancing the throttle before the prop, as long as the setting remains within the permissible operating range; even so, I would suspect that a brief excursion beyond that range wouldn't hurt anything. I have seen full throttle applied with the prop retarded all the way back for best glide range and the engine didn't blow up, although it didn't sound nice.
I have seen a lot of confusion about this before in all of the flight schools I have worked at. If you think of the MP/RPM relationship as "gearing" it usually makes more sense to the somewhat mechanically inclined. Imagine riding your bicycle up a steep hill. You would choose a low gear gear that allows your legs to pedal quickly with less resistance. This is the same thought process you should use while climbing an airplane. RPM is the gearing and MP is how hard the engine is working. During a climb, the best performance is going to come from a the highest RPM setting for a given MP setting.
Full report:
Excellent. Believe it or not, last night while falling asleep, I wondered what would happen if you shortened its diameter below published limits. While I am not saying that this happens to a typical McCaulkey on a 172, it is a neat point of reference to have going further.
