trafficinsight
Yeah, but I'm still not clear. If the POH makes no mention of static wicks, how is it that if they are missing, the airplane is no longer airworthy? "I'm am not understand!" <------In your best Apu voice.
When the airplane leaves the factory with everything that installed in it and on it working it "meets original type design" (from that definition of airworthy)
When the static wick breaks off, the airplane is no longer as it was when it left the factory so it no longer "meets original type design."
If the POH or another approved source says that the static wicks are optional then you have a basis for altering the aircraft, you can have them removed.
If there is no such data then no dice. The airplane must meet its original type design or be properly altered, you can't prove that the airplane was properly altered if you have nothing to back it up.
