Re: Combinations of RPM & Manifold Pressure
I would like to read the inspector's response.
Wow, I saved this back in 1998:
[FONT=Times New Roman, serif]
To:[/FONT][FONT=Times New Roman, serif]
John Deakin - jdeakin@avweb.com [Read][/FONT]
Fm:[/FONT][FONT=Times New Roman, serif]
Fred Harms - Fred_Harms@hq.faa.gov [/FONT]
Dt: 13 Apr 1998 [/FONT]
John [/FONT][FONT=Times New Roman, serif]
:[/FONT]
Just as in flight instructing, you never really learn about aviation safety until you try to write about it. [/FONT]
I read your original column and I understood the context in which it was written. In the Practical Test Standards, the FAA advocates that the use of a checklist is dependent on the specific task being performed and recognizes that proper scanning and division of attention may render the use of a checklist as impractical, especially in a single-pilot operation. The proper use therefore, is as a "check", not a "do" list. [/FONT]
The use of memory aids has also been accepted as a good procedure for accomplishing a task. The FAA "On Landings" safety program promotes the use of a GUMP[/FONT][FONT=Times New Roman, serif]
’[/FONT][FONT=Times New Roman, serif]
s check, but in all cases, when division of attention is not compromised, all actions should be verified by a checklist. [/FONT]
As an FAA inspector, retired Army instructor and flight examiner, I have given many checkrides. It is pretty easy to spot those pilots who rely on a flow method as a sole means of completing cockpit tasks, and I have observed that it only takes a minor distraction to cause a disruption in the flow. It often results in important items being missed. When a flow pattern is used, we are relying on our memory alone. A self critique is a great idea, but it only can happen when we realize that we've missed something. [/FONT]
One of the very finest checkrides I observed was for a young man taking a VFR single-pilot Part 135 evaluation in a Cessna 172. The pilot stuck the checklist in the plastic door molding just above his left shoulder. At each appropriate point, he would reach up with his right hand, pull down the checklist, quickly scan it to verify he had accomplished all the tasks, and return it to it's holding place. He used it for every operation throughout the flight, and he did it so smoothly that he never disrupted his traffic scan or negatively affected his division of attention, even in a high workload situation. It was such a natural part of his flying that the entire operation was seamless. He verified his flow with a checklist to know. When I hear people complain that using a checklist, even in a relatively simple aircraft, is an unnecessary burden, I'm reminded of the superior job this young man did. The other great thing is that he is also a CFI, so I'm sure that his students are learning to be equally capable. [/FONT]
When a 32,000-hour pilot writes, "Throw Away That Stupid Checklist!", not everyone is going to understand the context in which it was presented. [/FONT][FONT=Times New Roman, serif]
I understand your desire to be controversial and spark debate. Certainly, attacking one of the first, and most basic things we learn as pilots will accomplish that, but your words may have a more profound affect than you realize. [/FONT][FONT=Times New Roman, serif]
Considering this week's headlines - "Transponder Found Off In GA Midair" (AVweb Top News Stories, April 13th), your comment: "If you forget your transponder, the worst that will happen is that ATC will say, "confirm squawking," generally with a little chuckle, because they know what you did - or didn't do" might be the truth as you perceive it, but you may be doing a disservice to a relatively new pilot who accepts your words as "gospel". It might just be that the "worst" that can happen is not a chuckle from ATC. Could a checklist have made a difference? I don't know. We never will. In my job, I've seen many things that you eliminated from your "killer" list that have led to tragedies. [/FONT]
As I said in the beginning of this long winded thesis, you never really learn about aviation safety until you try to write about it. I commend you for stepping up to the plate and giving it a shot. Words are powerful things. They can produce positive or negative results. I hope you will continue to contribute to AVweb and that your words will always produce the positive results I know your looking for. [/FONT]
