seagull
No one has gained access, there are merely more flights to the larger markets that were already served. This is part of the problem; you don't think those smaller markets deserve service, while I believe every market of a reasonable size deserves service, because the airlines should be viewed as public utilities, essential to the economy. They should not be viewed as just any other business.
First, the argument is that the reduced fares allowed more access to air travel for more people. The loss of service to smaller cities is totally unrelated to deregulation, but instead an issue related to Essential Air Service.
You seem to have a reading comprehension problem. I never stated that fares didn't fall, I stated that deregulation wasn't the cause, and I pointed out that the biggest drop in fares took place before deregulation, not after.
That is really a misrepresentation. The fares dropped during that era as a direct result of the onset of the "jet age", which hugely changed the dynamics. There was no similar facet after deregulation. The drop in airfare after deregulation was related directly to deregulation, while the drop previously was due to a major change to the platform used for operating.
Not at all. My argument is based upon Occam's Razor: the simplest answer tends to be correct. When you see that overall economic growth has increased at exactly the same rate that RPMs have increased, what is the simplest answer? I think it's pretty clear.
Absent deregulation, if there had been an increase it would be been with fewer pilots on larger aircraft. The advent of the regional model was not possible prior to deregulation.
Of course I'm aware of that, but I don't find it anything to be bragging about. Are you aware that, corrected for inflation, Continental pilots were making nearly that much as far back as 1940, when they were little more than a regional airline? Are you aware that, corrected for inflation, Pan Am captains could earn nearly $700k in '78? Are you aware that as recently as the '80s, 19-seat turboprop FOs could earn $30k first year? I can't believe someone is even trying to defend current compensation, or trying to claim that it used to be worse. We all know it to be false.
Are you aware that is a totally inane way of looking at inflation? That wages, particularly over the median, NEVER keep up with the market basket of goods that are used to determine inflation? Makes sense too, because those items represent a very small percentage of a higher wage earners salary. Pilots, even Capts at most regionals, fall above 87% of the population in terms of wages. Further, inflation itself is a very debatable number as the value of certain things has changed, for example, a typical automobile today has a lot more value than one that was sold in the 1960s.
I hate to break it to you, but you're clearly in the minority on this thread.
Actually, not.
