The hypothetical scenario is exactly as I posted above.Depends are they smoking said illegal substance?
AhCall the destination FBO and get them to go out and get some Tbell for said passengers.
One of these days you'll learn to think outside the bun and the box.
-mikecweb
Well, if they're not smoking, I would leave it alone.
You're not getting it or I wasn't clear enough.
As I said...you smell something funky. Now what do you do.....from there......?
I've thought about this one a lot and know what I'd do (job be damned), but I'd like to hear how others would handle it.
-mini
-mini
-mikecweb
found this for you hope it helps .....
Second hand marijuana smoke in a car can cause you to fail the next day' (Nightbyrd). It is possible that second hand [marijuana] smoke will raise someone to the 50 ng/mL level; however, *extreme* exposure is required. For instance, a closed car full of pot smokers and a non-smoker may render the non-smoker positive for both urinalysis and the hair test, provided that they are sealed in the car for a while. The Army did a case study where volunteers were put in a room pumped full of smoke for an hour, five time daily. Subjects started testing positive after the second day. The non-smoker would have to take in virtually as much second hand smoke as a smoker. Non-smokers are safe in a ventilated area, as long as they don't get a hair test. According to Clinton, simply blowing crack smoke on ones hair may cause a positive hair test. Second hand pot smoke doesn't affect the hair test results as much as crack smoke does mainly because exhaled smoke contains no THC. The only pot smoke that contains THC is the smoke that hasn't entered the lungs."
BTW ...I was just generalizing .....but lets hope we were just talking about nicotine or canibus at worse.
How about if they leave some drugs or some residue on the airplane and on another trip you are returning from an international location and customs finds it?
I know on boats the Coast Guard can inspect you and during the inspection they will do a swab test to see if drugs have been used on the boat. Does customs inspect airplanes the same way? I do not know since I have not flown out of the country for several years.
So you're the captain. The pax walk up and ask you to turn out the cabin lights (because for some reason you insist they be on during flight......but that's another discussion) and about 10 minutes later, you smell something "funky". *ahem*
What do you do?
-mini
My thoughts:
We do not allow smoking, so a flip of the lights and a look back is important to begin with.
Why?
1) How do I know there isn't a fire in the cabin? It might not be smoking that I smell.
2) I tell every passenger that there's no smoking. So they need to be reminded that's not allowed.
If I can verify that they are smoking, I tell them to stop...if it's something illegal, I declare, have the po-po sent to the airport, then put on the mask and start down. After getting in, I get pulled off of "the line" for drug testing and to get my clothes cleaned. If the company doesn't want to clean the plane, they can send me home.....I'm just not dealing with that crap. The fact that they paid $xx,xxx for the trip doesn't concern me.
-mini
