Pay attention to the person he posts to. When he speaks to someone newer on here, he dumbs it down to be less technical. When he talks with me he will give a formula and explain it, because we understand it that way.
If he talks with fish, I go get a bag of chips and pretend I know what is going on.
Here is a translation, see if I can get this right:
I wouldn't argue this, but I'd be skeptical taking it for face value or presenting it to a student. That said, I have no translation until tgray gives more information into his thinking here.
This might be over simplified for you, but here:
Using a basic formula to demonstrate relationship of lift to speed and AOA we can write:
Lift = speed + AOA
Since lift always equals weight, whenever pitch is constant, we can assume lift to be a constant number. Let us keep them small, don't want to scare anyone with big math numbers, and say lift is 10. We have 5 speed and 5 AOA.
10 lift = 5 speed + 5 AOA
We can change AOA to but now we still have to keep lift at 10, so:
10 lift = some speed + 4
Some speed must be 6 to keep lift at 10. This is a clear demonstration of lifts relationship to speed and AOA. Speed and AOA vary inversely to keep lift constant when pitch is constant.
Knowing for sure now that speed varies inversely with AOA, and changes because AOA changes, we can refer back to this quote. Reread it and now understand the relationships, ignoring lift coefficient.
...did you reread!...? ok...
Lift coefficient = pi * AOA
So all the last part says is that changing AOA will make lift coefficient change. Here:
Remember pi from math class? It equals 3.14, so..
6.28 lift coefficient = 3.14 * 2 AOA
Let's change AOA from 2 to 3 and see what happens:
3 AOA * 3.14 = 9.42 lift coefficient
So we can see that is true.
Finally...
Reread this a few times over, paying attention to the comma that was added and substituting the bold word with: lift. Since lift is merely a difference in pressure, why not use a simpler word to reduce brain strain.
Did you word this funny or did I have too much to drink (my bday in 15 min:beer
Ok T, a quick thought experiment:
Takeoff at sea level, trim for a perfect 75 knot climb. As you progress through 5,000, have you changed trim? How bout 10,000?
It has been a long time since I have done a progressive climb to 10,000+. However, the last time I did, I don't recall changing trim, even to 11.5 to get over Philadelphia.
Am I wrong? If I am right about this I am right about feeling the pressures on the yoke too. I'll explain after we agree on this though.
Mini - Are we on the same page with use of senses like instruments and such?
