darrenf
resident denizen
Thats why we butt heads sometimes, cause you like to drive in circles!![]()
Nope, used to work in the industry, only ever participated in drags though. 1320' suits my attention span a bit better.
Nope, used to work in the industry, only ever participated in drags though. 1320' suits my attention span a bit better.![]()
Read the profile, he really does sell grass.
All of these things are surmountable, it'll happen eventually.
Sweet.http://www.pscaracing.com/driverprofiles/Outlawnuke.html
This is my brother. When I didn't work seven days a week, I used to help at the races.
Is that kilograms per liter?The amount of lead in 100ll is 0.721 kg/l. Some stays in the cumbstion chamber, some goes out the pipe. Gasoline content of carbon 2.1 kg/l. More than double.
I think Jet-A burning diesels are more likely to happen first. Lycoming and Continental will probably decide that is more profitable to design and certify those![]()
Ethanol is incompatible with the hoses seals, gaskets, and other parts in current engines.
It also needs a fuel heater for cold operations, however it can work on any mixture 100ll to ethanol. The plus to ethanol is an increase in performance, a major downside is that you lose fuel efficiency.
I flew a loaded C-152 running on ethanol in the TX summer and was amazed at the kind of performance we got out of it. You can get around 15% more hp on ethanol(I forget the exact number, I'd have to dig through my books to find it). Also, we ran a 95% ethanol 5% water mixture and got better performance than a 100% ethanol mixture. I know it sounds weird, but if I wasn't the one churning out the data for my prof I wouldn't have believed it.
Right until the end I was like...
Did your research get published?
In the big picture, I'm not sure how much more development we're going to see for gasoline fueled piston engines, as diesel powerplants (that can burn Jet-A) have a much brighter future.
100LL has between 1.2 and 2 grams of lead per US Gallon.
I disagree, I think that unless you can get new airplane prices down to reasonable levels then it'll take many years for that to happen... and even then Jet A is not panacea. The diesel 172 stats were dismal.
A light airplane is an absolutely perfect application for a diesel- low RPM, high torque, and relatively constant load. There is always going to be a lower BSFC (Brake Specific Fuel Consumption) for a diesel than for an Otto (gasoline) cycle engine. This is good, as it means less fuel burn for the same amount of power.
Until someone can figure out a way to cut the cost of a turbine engine down to under $50K, or some other form of powerplant becomes viable, piston is where it's at for a small aircraft, and diesel makes a heck of a lot more sense than gasoline, especially since the available gasoline engines we have to choose from are still using 1930s technology.
The problem with the Thielert converted 172 was an overall lack of power, since the engine simply did not put out enough. This equates to the wrong choice of diesel engine, not to be confused with a blanket statement that "diesel is bad."
However, you are correct, in that it will never be an attractive proposition to hang a diesel (or any kind of new engine) onto an older aircraft (and "older" in this case could mean 5 years), and thus yes, we do need a replacement for 100LL to fuel the remaining piston fleet.
