V-G Diagram
conner
Why is the V-G diagram based on indicated airspeed? Does anybody's plane have a V-G diagram? If so, is it specific to a given weight and altitude?
Thanks
Ok. Couldn't I be flying at the same IAS but a higher TAS and therefore have greater lift capability?
Nope. Because the indicated airspeed for the stall remains (more or less) the same. If the airplane has a high enough TAS, you may even get a reduction in lift capability due to mach effects, but that's not really an issue on most piston airplanes.
