1st in-flight failure
I remember my first failure of this kind. I won't fool you with stories of how cool I played it, and how sure I was of myself. I was scared, and I did stupid things. I didn't think it through, and I almost bent up an airplane.
Early in 2006 I had decided to pick up a friend that was visiting me in FL. I had received my PPL in December '05, so I was a fairly new PPL. This trip would take me into the very busy airspace of Orlando International. I was a very bold PPL. Perhaps this was the beginning of my error chain. This fact put a lot of pressure on me to complete the flight, and I was nervous having never been to this particular airport. I was also making this flight at night. I was rushing myself during pre-flight and initial taxi and run-up. I was running late, and I wanted to be there before my friend landed.
During my engine run-up I noticed some considerable static feedback in my headset. I wasn't sure what was causing it, but I was annoyed. Everything appeared normal, so I thought little of it, and took off heading towards Orlando.
I picked up flight following once I left the airport vicinity, and everything was proceeding fine. I was fat dumb and happy in my little Warrior, buzzing towards a large class bravo primary airport. My cockpit was overall pretty dark. The moon was out that night. I had most of the lights turned down low, to enjoy the view of the Florida coastline at night.
A bright amber light illuminated my mostly dim and dark cockpit. As if connected to my adrenal gland, this little light with the letters ALT on it got my heart racing. I was solo, at night, and I was experiencing my first ever electrical failure!(Or so I thought at the time)
I began to panic. What would happen if the battery died and I couldn't turn on the runway lights? Would I be able to land without a landing light OR runway lights? How will I ask for help if the radios go dim? I momentarily considered continuing to my destination. I quickly dismissed that thought, and told center of my problem. I'm certain to this day I sounded just as scared as I was. My voice trembled and my uncertainty was surely clear. I didn't know what to do first. I didn't know where I should take the airplane. I was trying to do everything, and yet I did nothing.
The first airport I tried to go to didn't have airport lighting. I sure tried to turn the lights on though. I didn't even look to see if they had lights, I just tuned in the CTAF and clicked like a mad man. I was clicking the PTT so fast it hurt my finger. The center was extremely helpful, and told me of the closest airports I could go to. I made a turn for another airport close by.
This one had lights. I was only slightly relieved by the fact that I had the airport in sight, and the runway lights were on. I have no reason to panic at this point, yet my adrenaline was flowing and I was still worried about not being able to see the runway. I told the center I was going to shut everything off to conserve power. (The airport was less than 10 miles away, and I was sooo concerned about losing power)
Here I am. Panic stricken, and chocked full of adrenaline, plowing towards a non toward airport at night in what I believe to be an airplane about to have the wings fold. I was focused on landing. That's all I wanted to do. I wanted to be on the ground, and done with it.
My approach to the airport was excessively fast. I was coming down final at 120 kts. I wanted to be on the ground as fast as possible. Well I got what I wished for. I got a very fast approach, fast final, fast flare, fast float, fast float, fast float, fast float, and touchdown.
I touched down with less than 1000 feet of available runway remaining. I exited the runway on the very last taxiway after a very firm amount of braking. The distinct smell of smoke entered the cabin. I probably put a few flat spots on those tires.
I sat in the airplane with the engine idling just clear of the runway. I was replaying what had just happened, and how I had gotten to where I was. I couldn't believe how close I came to not making it on the runway. During my long float I considered going around. I decided against it because I didn't want to fly anymore. I wanted this airplane on the ground.
If you're familiar with any electrical system, you know that most incorporate a voltage regulator and even an over voltage relay. Had I kept my cool, and opened the checklist, I would have been able to reset the relay. This would have solved my insignificant 'problem'. The truth was I had no failure. It was just a voltage spike that shut the alternator off. Just flipping the ALT switch off and then back on would have made my entire 'emergency' go away.
Since this 'incident' I have had multiple electrical problems, gear warnings or indication failures, engine power loss and roughness, and even total power loss. Every time something happens, I remember this flight. I remember the mess I almost created from nothing. I take a deep breath, and slow down my actions.
That is the most important lesson a pilot can learn. The take away here is that in any emergency, the first thing to do is RELAX! Wind the clock, then pull out the checklist. Other than a stall or windshear, there are very few emergencies that need you to do something right now! Even engine fires, and yes, I've had those.
TXaviator is such a great pilot, they've made an entire joke list for him:
[FONT=ARIAL,]TXaviator doesn't request clearances, he states intentions.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] never gets vectors to final . . . final gets vectored to [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,].
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is the only person ever to land on runway 37.
Hijackers squawk 7400 when
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is on board
If you ever lose sight of
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,], check your six o'clock.
When
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] taxies onto the runway, incoming traffic is told to hold short
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] never "loses" altitude, he simply gets rid of it when he no longer has any use for it.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] has never landed with a crosswind. The wind would never dare get cross with [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,].
When
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] flies, the altimeter setting is 00.00. [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is never under pressure.
When the BASH condition is Red, planes don't fly. When the BASH condition is
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,], birds don't fly.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] has never had a midair collision, He has shot down any plane that has gotten within 10 miles
When told to break at the numbers,
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] politely reminded the controller that [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] cannot be broken and proceeded with the straight in.
Right of Way rules do not apply when
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is flying. If you are flying toward [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,], you are wrong.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] doesn't shoot approaches...he kills them.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is never off of glideslope, the glideslope is off of [/FONT][FONT=ARIAL,]TXaviator[/FONT]
[FONT=ARIAL,]
Chuck Yeager broke the sound barrier with his Bell X-1.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] broke the sound barrier with his fist.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] doesn't manage operational risk...he seeks it.
An ejection seat is not safe until
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] gets out of it.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] doesn't need crew rest...he never sleeps.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] was once denied a clearance...once
Minimum Safe Altitudes do not apply when
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is airborne,if you are in the air when [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is flying you are never safe.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is never given the instructions "when able" . [/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is never unable to do anything.
Favorable winds are always in the same direction as
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,]'s flightpath
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] has never had to adapt his eyes to the dark. His infrared vision is working perfectly fine.
T-45 Anti Icing Capabilities: Pitot Heat, 5th Stage Bleed Air,
[FONT=ARIAL,]
A permanent TFR surrounds
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,]...no one is safe.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] cannot be tracked on radar, if he appears, it is too late; you are already dead.
A good flight for
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is a bad flight for you.
Leading cause of disorientation for pilots:
[FONT=ARIAL,]
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] once moved a stationary front.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] is the only person to graduate SERE School via correspondence.
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] isn't holding, he is circling above his victims.
The weather outlook for the area around
[/FONT][FONT=ARIAL,]TXaviator[/FONT][FONT=ARIAL,] : 100% Chance of Pain[/FONT]
[FONT=ARIAL,]
[/FONT][FONT=ARIAL,]Think we should all power to TXaviator's prowess. He is clearly the biggest baddest pilot here.[/FONT]
As Blizzue stated, the best thing you can do in a nonfire related problem is to take a breath and think about the problem. I see you did a good job of getting the airplane to the ground safely so kudos to you.
Someone told me a three step process to problem solving.
1. Identify the problem.
2. Fix the problem.
3. Deal with it.
Say you have an alternator failure.
Well, alot of airplanes have an A or ALT or some sort of annunciator that says "Hey, we've got a voltage issue".
Ok, problem identified.
What can we do to fix it? Checklist? Does it fix it? Yes or no?
If its fixed great, if not, deal with it. What is going to happen in the long run, or in the short run. Most problems in airplanes are not going to kill you. Only inconvienence you. As Bliz stated, an electrical problem is only an emergency if you let it become one.
An engine failure or fire can be different.
I remember when I was flying a student and we got the good ol ALT annunciator. Well, we took a look at the checklist and followed the steps to alleviate the problem. No dice.
So we turned back and flew the 10 minutes back to the airport. Was it an emergency? No, would it have been if I had lost all electrical power? No. Turned out the belt had torn. But it wasnt an issue of safety.
Remember, sometimes being in a hurry can cause more problems than they fix. There is a time for immediate action, and knowing which problems require that and which do not is part of being a good pilot.
Otherwise, good job and hope your problems stay away :)
Welcome to the club. My first in-flight failure was also an alternator/loss of electrics failure. I had just under 100 hours and was flying off the insurance co required 10 hours in a 182 with a CFI in the other seat. I handled it just fine, but I'll admit having a CFI sitting next to me made me a lot less nervous.
In retrospect, I think I was more nervous about having to do a no-flap landing in what was then a pretty new to me airplane than not having any radios. And on that score I'll say that while its perfectly understandable for someone with your experience to be nervous at the thought of having no radios in an uncontrolled pattern, it really isn't something to fear.
I would suggest that you take this learning experience and build on it. Find a CFI or even a crusty old pilot whom you trust and go out and work on 'old school' pilotage navigation skills and NORDO ops. Its not hard to master and once you do, you'll never again bat an eye lash at the thought of losing electrics while on a cross country and having to find an airport with nothing but a chart and windshield.
Garmin systems can be configured to do that in the event of a power loss. I believe the G1000 is setup to automatically switch to guard following a number of different failures.
Hey, good to know ESA, thanks.
I lost my radios the first time I took my mother flying. I did everything by the book and didn't tell her anything was different until we had landed. She told me that she was impressed that I managed to handle the situation without her knowing and that she was happy I didn't tell her anything until we were back on the ground. I dunno why she would have been so nervous, it's not like my radios were keeping me aloft.
Anyways, good job on maintaining composure and flying safe.
[FONT=ARIAL,]
hahahaa that was awesome! :rawk:
i should start wearing FIVE stripes to captain my 172 around the skies!!
Handling any failures with your mother in the plane without her knowing takes serious skill and talent. :D
Enjoyed reading all the posts. Yeah, it got my adrenaline running some. I have certainly had it running a lot more though in other situations, but being a fresh pilot, I've never had the time for anything to really hit me yet. In the 172M I fly, we have no lights to tell us what is wrong, but do have circuit breakers, all of which were in. Probably a shortage or alternator from when I spoke with the mechanic.
As far as what frequency I was transmitting on in relation to "guard frequency," I have no clue. The plane has a COM1/NAV1 & COM2/NAV2 radio system. The G430 handles COM1 and it was completely out. I then thought "hey...no worries, I'll just use our handy back up radio." Went to change from the AWOS frequency to the CTAF and it was flickering, but the audio control panel was completely out as well, so I couldn't select COM2 to transmit on. :(
Oh well, it was an experience to remember and learn upon. I'm sure I'll have many many more to come.
I had pretty much the same issue in a 172 last summer (I had around 100 hours or so at the time). Nothing that really made me sweat but I was kind of scratching my head since the ammeter wasn't showing a discharge. It took me about 3 go arounds (no flaps, short runway, middle of nowhere) before I finally got it where I wanted it and landed hahaha. I landed and went inside and decided to try to plan a route home that would avoid C airspace before I realized I wouldn't be able to start the stupid thing back up anyway. No cellphone reception so I had to use the golf shop across the way's phone right before they closed to call a CFI from the flight school to come get me on a Friday night. Ended up leaving the 172 and taking off in the 150 right as night fell. Feel kinda bad for him looking back on it. :D I hauled the new battery down there the next day with their mechanic and they fixed it up and flew it out. Each time I've flown that plane since it hasn't been an enjoyable experience. I did some hood work in it a couple months ago and thought I was just tracking the VOR pretty damn good. Turns out the CDI had quit working. :bandit:
What kind of avionics set up do you have that defaults to transmitting on guard?
More like a :tease: instead of a :cool:
Come on dog.
Oddly one of the Marchetti's I fly has a radio that turns on with 121.5. I will get you the make and model as I dont remember.
hahaha, I'd take it as a bad sign if I started up an airplane and the plane decide it would be better off on guard. :laff:
My first solo round-robbin cross country in a C-152 ended with an alternator failure and eventually a total electrical failure; I tried to preserve the batteries by shutting the radios off, but eventually I had to turn them on again to lower the flaps and contact approach. Took the light gun to a full stop and taxi'd back to the ramp. Strangely lost comms seem to be a common occurence for me. Went lost comms in the traffic pattern on my first solo in the T-34C (again light guns, landed full stop), and ended up being a nordo (lost comm) wingman on one of my first formation solo hops in the T-45C (just followed lead home, and he coordinated my clearance to land). Anyway, I'm sure it was good experience for you, and I think it probably showed you that while disconcerting, it is not the end of the world. If nothing else, it's nice to not have to talk to anyone, right? :beer:
I had a dual generator failure at night IFR in the 320. I hate the thing sometimes. Really got my heart pumping, probably because it was -10 out and the heater quit, but hey.
Yep, it's nice not to talk to anyone. We had some good ole country fellas talking on the radio about 10 minutes before we lost the radios. They seriously held up the friggin radio for 2 minutes talking about flying and where they were going and about the pollen and so forth. Seriously? Is it necessary to block a frequently used frequency just to talk? But yeah, I was confused when told "You are transmitting on the guard frequency" b/c the Com2 radio never showed 121.5. It showed my home airport AWOS and a different standby freq., but not 121.5 so that also kinda threw me off, but it was nice that it somehow automatically went to that in a way if it was a "real" emergency.
They were the only ones able to communicate w/ me which is just really strange considering the radio was flickering and nobody else could hear at all. :)
