You're right. It doesn't. The people who say it does are misinformed.So Does an CFI Initial Count as a Bi-annual Check? I've hear yes and No.
I don't believe it does because the CFI Certificate is a Instructor Certificate, where as the Bi-annual is for a pilot Certificate.
What is it?
Thanks
I do agree with the two above posts. But I know a certain FSDO inspector that is absolutely furious over the Levy letter. If you can pass a CFI ride, then you can have a FR so he says.
And why shouldn't it. In the CFI PTS on page 5 it says
"the ability to demonstrate and simultaneously explain the key
elements of a TASK. The TASK demonstration must be to theCOMMERCIAL PILOT skill level2"
So essentially, if you go outside of tolerance in the Commercial PTS, you just busted your check ride.
Since this is in the PTS, I think we should all write Ms. MacPherson and either have the quoted above removed from the PTS, since I have seen people bust CFI rides for no meeting commercial standards, or have a CFI ride count as a Flight review (minus the II).
What sayith you? The reason I bring up a letter writing campaign is because I am sick of this issue being brought up all the time with all of the confusion surrounding it.
As has been discussed on here many times, Midlifeflyer is right on this one.You're right. It doesn't. The people who say it does are misinformed.
http://www.faa.gov/about/office_org...00/interpretations/data/interps/2008/Levy.pdf
:yeahthat:I've met more than one examiner that would sign off for a flight review after the completion of a check-ride. All you gotta do is ask.
Also, if you're ready for a CFI checkride...
What do you have against annuals that swing both ways? :joke:
Why would you want that removed? All is says is that when you demonstrate a maneuver as an instructor, you need to be able to do the maneuver to commercial standards. Makes sense to me without having to extrapolate it beyond what it says.I do agree with the two above posts. But I know a certain FSDO inspector that is absolutely furious over the Levy letter. If you can pass a CFI ride, then you can have a FR so he says.
You can just as easily make the point that since a CFI requires a commercial certificate, who isn't he also required to have a 2nd class medical (instead of none or at most a 3d class).I think the point being made was that if the FAA doesn't deem a CFI ride as a "proficiency check" or is not "primarily focused on piloting skills" then why have the commercial standards in the PTS.
Also, if you're ready for a CFI checkride, you should know it's biennial (which means once every two years) as opposed to biannual (which means twice a year).
And check 61.56. It's now a "Flight Review." No biennial mentioned.
I understand the title of 61.56 is "Flight Review", but aren't you splitting hairs to say it's not a Biennial Flight Review. Is it better to say a Flight Review, done biennially. I have never read the entire regulation, so maybe there is a valid reason in there to drop the "biennial" part, all I know is I have to get one every other year.
I do agree though, I hate seeing, and hearing "biannual flight review." I even saw it in a letter from the airport where I used to fly at. They wanted a copy of everyone's "biannual." I'd like to meet the pilot that goes above and beyond, and gets them, without having too, twice per year
The point isn't very sharp in either case. What is the teacher applicant supposed to do? Keep bank within 80° of target when doing steep turns?
As far as the medical goes the reason for no 2nd is because a CFI is not making money as a Commercial Pilot, but rather an Instructor. Not really relevant when talking about a Practical exam being a proficiency check.
Simply put, if the FAA doesn't believe a CFI ride is not a "proficiency check," then why have the candidate fly to a set of standards which in itself shows a high level of proficiency.
If it truly is based on instructional capability then take the Commercial Standards out of the PTS, have the DPE fly the entire ride and the CFI take the controls to demonstrate or recover, and have the applicant actually instructing the whole flight.
Even more simply put, because he's supposed to be teaching it to others.Simply put, if the FAA doesn't believe a CFI ride is not a "proficiency check," then why have the candidate fly to a set of standards which in itself shows a high level of proficiency.
And you buy that little piece of fiction and not that an instructor certificate is not a pilot certificate?As far as the medical goes the reason for no 2nd is because a CFI is not making money as a Commercial Pilot, but rather an Instructor.
