btw: I did the new procedure today, I survived
If you have ice on the roll to begin with, taking off is probably not the smartest course of action.
True and, in those cases, I heard you can also hover over the ground if your indicated airspeed is 0.if your airspeed indicator freezes, you will never lift off the ground because of insufficient airspeed. also, if it freezes in flight, you cant land bc the a/c wont slow down.
beware. you might die!
It really depends... Is the right cowl flap open or closed?what if you put a UND seminole on a treadmill but only ONE main wheel is on the treadmill, and the other main is on solid ground, then fail an engine... what happens?!?!?
I'll have to differ. I guess we'll just have to submit this one to Mythbusters.angel you should know that if you take off with the cowl flap in the wrong position the plane will crash. its on your do-list.
dear mythbusters: please evaluate the UND SOP's. please point out any falsehoods. thanks.
Why do you hate life?
i actually have a fairly great time, now that im away from UND.
I personally like his attitude.
A little apathy never hurt anyone! :rotfl:
i wouldnt call it apathy. its more of a severe case of realism.
Its not your fault.
