Neither is a law of physics...Now, with almost 30 years of flying and nearly 10,000 hours total time
The belief that flight time qualifies one to make this claim is the epitome of most wrongs in aviation today.
WOW!! Lets take two ideas from two separate paragraphs and thoughts, and put them together into one statement so we can manipulate the statement to our liking. You should work for the media!!
And your same quote could be said about 500hr pilots that think they know everything too!!
What statement? I read him to say that we are all discussing technique. That his first flight training experience was the pitch to airspeed mantra, then had to learn the pitch to flight path mantra, then after many thousands of hours working both, has learned that it takes experience in both. I thought he was speaking to the experience level, not the knowledge level.The point was that pilots, regardless of hours of experience, are not qualified to make such a statement.
What statement?
A bold statement he isn't qualified to make and one that is entirely wrong.
Wrong, am I?
Then why does it work?
P = mV
The better answer
Hence the name "region of reverse command", which I find more informative than "backside of the power curve."
I've watched many pre-solo students continually add power alone in this scenario, resulting in a continually decaying airspeed and further altitude loss. I will not solo them until I see them recover properly from this scenario.
So was my answer wrong or just not as precise as it could have been?
You said neither is based on physics.
Why do airlines make certain techniques into procedures?
There's one thing that is for sure, no matter how much we debate this technique of flying there will never be a clear cut answer.
With that being said I teach in light single engine airplanes and have found that pitch=airspeed, power=altitude is the best way to teach it
If you teach a student that pitch = airspeed, if the engine fails you can bet the odds are a lot less that a student will stall-spin the airplane into the ground.
I said that neither technique is a law of physics.
I'm referring to using each technique throughout the entire range of airplane operations.
Standardization.
Both techniques fail when they are applied incorrectly.
For example, a student flares too high and is now too high and too slow. If he applies the pitch=A/S technique he'll lower the nose and reduce power.
If someone is saying that only one technique works then that person doesn't understand them both.
For example, a student flares too high and is now too high and too slow. If he applies the pitch=A/S technique he'll lower the nose and reduce power. .
Larry, you can't come up with a scenario in which using AoA to control airspeed and excess power to control altitude will not work, because that's the way that both techniques work, no matter how the pilot chooses to think about it. I have four shelves of aeronautical engineering texts that say so.I can come up with similar scenarios for, or against, either technique.
OK, I'm with Larry on this one. And remember, we are talking about primary student reaction based on the rote rule of "pitch to airspeed, power to altitude".Larry, you can't come up with a scenario in which using AoA to control airspeed and excess power to control altitude will not work
And we (me and tgrayson) have both pointed out that this is wrong. One technique is entirely based on physical law.
They are techniques. They both work. I haven't commented on which, if any, I prefer. I've said only that I can fly, and teach, them both.
You cannot use pitch for glide slope (altitude) in the region of reverse command.
It has nothing to do with one technique being deemed safer than another? I am not trying to badger, I legitimately do not know and would like to know. Thanks.
In light pistons, pitch = AS | power = alt, will not fail if applied in any situation ever. Nobody on this thread has yet to come up with an example when it would. (Pick your jaw up till you read the next section)
Why in the heck would the student decrease power. Your scenario accounts for low and slow and the technique, applied properly, would be an increase in power and a decrease in pitch. The student is trying to control their descent rate (power) and increase their airspeed (pitch).
I don't think anyone said that pitch for glide slope doesn't work. What it has to do with, at least in the private level, is habit patterns. Habits are responses (actions/inputs) we develop through practice/use that become subconscious responses to given situations. If you always use pitch when you are sinking to control altitude, that can fail in certain situations. IE region of reverse command, inevitably leading to stall/spin.
