[modhat]The first 60 posts in this thread were originally intertwined in the Icing thread. I moved them here to separate the two topics.[/modhat]
I understand and agree with your main point (promoting real understanding of what constitutes icing conditions), but I disagree with the implication that pitot heat can be skipped on the prefilght checks. That sets a bad precedent with lots of unintended consequences.
All of the information in this thread is fantastic for instrument rated pilots. But for student pilots, 90% doesn't apply.
I've found the majority of student pilots and inexperienced private pilots don't have a good understanding of ice, probably because they've heard a lot of terrifying rumors and occasionally some misinformation or incomplete information from their CFI.
When I fly progress checks with student pilots, even when it's clear and a million, a lot of times during the preflight check they'll ask me if they should check the pitot heat. The conversation usually goes like this:
I say, "Well...if you want to, sure. What would you need the pitot heat for today?"
"In case we pick up ice."
"Oh...ok...why would we pick up ice on this flight?"
"Ummm...it's below freezing out...so...ummm...maybe we'd pick up ice?"
"Ok...has anyone ever talked to you about where ice comes from?"
*blank stare*
"Ice doesn't appear out of thin air. It needs two things...below freezing temps *and* visible moisture. And when I say 'visible moisture' I mean, clouds, fog, rain...those types of things. Not just a thick layer of haze. So as a VFR private pilot, all you need to worry about is staying out of the clouds, and staying out of freezing rain. If you do those two things, you'll never have to worry about ice...or check the pitot heat, for that matter."
I've had this exact conversation with about 4 or 5 student or VFR private pilots now, who were taught by multiple instructors, so I know this is a widespread issue. If you're teaching this stuff, please be very clear with inexperienced pilots that you're talking about a phenomena that will very likely never apply to them if they follow the other rules in place for them.
Otherwise you might end up with a private pilot who has completely irrational fears, like thinking the plane will magically ice up and plummet from the sky if they go flying on a nice VFR day in the winter.
