why doesnt it work? I havent had (or heard of) any problems with PSP TRSA becoming part of Socal approach
From the website:
Loss of Local Knowledge
When approach radars are shut down at local airports and shipped to a remote location, invaluable knowledge of the terrain and geography surrounding these airports disappears. Thorough knowledge of the local geography surrounding an airport is an invaluable tool for air traffic controllers. In fact, local knowledge helps save countless lives every year. (see youtube videos below this quote)
Diminished Service
When approach radars are transferred to large radar hubs, the level of services provided to general aviation aircraft is often diminished. These large radar facilities often provide radar services to larger metropolitan airports catering to commercial airlines. While FAA procedures dictate that commercial aircraft receive priority, local airports and their general aviation constituencies often see a decrease in ATC attention when approach radars are taken away from local airports.
Safety & Efficiency
FAA statistics show that large radar centers typically have over 63-percent more operational errors than combined Tower/radar facilities. Cost estimates also show that realigned facilities typically cost more to operate than the current system. There are countless examples nationwide where local ATC service has been diminished following the realignment of a approach radar as controllers overseeing the airspace are no longer located anywhere near the airport.
Videos from the website:
[YT]auLXapJ1P28[/YT]
[YT]oQuwfMpJifU[/YT]
About PSP. In the presentation, the NATCA spokeswoman mentioned that there was a DOT audit done on staffing levels for SOCAL prior to picking up PSP. The audit found SOCAL severely understaffed and that facility had one of the highest operational error rates in the country. After the consolidation, operational errors went up drastically.
As the website stated, there is a loss of service for general aviation. In Toledo's airspace currently, there are about 25 satellite airports. About 95% of those have instrument approaches. Imagine having an instrument student wanting practice approaches, sitting on the ground idling waiting for an approach control that is so busy with the airlines that you can't get your clearance. And you wait. And wait. Looks like that hobbs meter clicked over another tenth for the third time. Sure you can call FSS, but you'll wait there too and likely be so angry you'll throw your phone out the window. Toledo TRACON currently is VERY tolerant with practice approaches and will even give radar advisories when doing air work. I'd rather not see that service go away as it makes it safer for everyone in that airpsace.
This plan doesn't save any money either. They have to pay for controllers to move, pay for more controllers, pay them more money for working in a busier facility and build the facility itself.
Not to mention the fact that if you have some kind of power outage or an equipment malfunction at this consolidated TRACON. It happened in Memphis. So you have the entire northern half of Ohio without radar coverage with DTW TRACON, CMH TRACON and ZOB trying to pick up the slack. Good luck getting your clearence then.
Another reason. TOL, MFD, CAK, YNG are all up/down facilities. This means that Tower controllers and TRACON controllers are the same thing. They're able to do both jobs and on a typical shift, they rotate through the tower and TRACON. This new TRACON is not up/down. This means that if somebody calls in sick in the TRACON, they can't have a person who's supposed to be working a sleepy ground control come down to the TRACON to help out. This results in a controller working extra sectors all while the system is getting bogged down. Good luck getting a clearence or radar advisories then.
Look, I'm not a part of NATCA..I'm am against this because I'm the user of this system. I
like being able to get radar advisories for airwork. I
like being able to get separation services on a practice approach. I
like to be able to get my clearence in a timely manner when doing IFR training flights. It helps me get the most efficient use of the time I'm paying for. With the new consolidated TRACON, this entire paragraph of positives turns into negatives. I also believe that the airspace will get less safe because of it.
I realize I only talked about Toledo in the majority of my post. A lot of these things are true elseware, too. MFD is a good place to have students learn practice approaches, as someone else said. CAK has a lot of airline service going on. YNG has airline service, GA, and ANG like Toledo. This plan just really doesn't add up in the sensibility department.
