Normally the gravity feed plus the engine driven fuel pump will do the trick, that said, if you lose the engine driven fuel pump, and it wasn't a failure in the accessory gearbox that did it (which would probably kill the mags, so you'd be a glider) then you could click on the electric pump, and it should provide enough pressure. That said, in bigger turbine motors that require a lot of fuel, the aux pump may or may not do it. I remember that if you lost the primary fuel pump in the 1900C (the 800PSI pump) you'd have an engine failure, because the aux pump only provided something like 15PSI, and wasn't enough to meet the flow demands of the big pump.
That said, there are smaller pumps in some turbine motors, which are used to prevent cavitation of the fuel. PT6 is an example that comes to mind.
