oktex88
I was out flying a Piper Seminole today that had just got out of maintence.. was cold soaked and she wouldn't start so had to get a preheat to start her up.
Anyway, I got her up to cruise and leaned out the engines... the left engine leaned out fine however the right one seemed to lean out (EGT peak) with a way cooler EGT than the left. I also had trouble keeping the Manifold Pressure even with the left engine with about an inch difference in throttle settings which seems to be a lot more than the other seminoles in our fleet I"ve flown.
After some manuevers and getting setup for a GPS approach I bumped up both throttles to full power to there a little quicker and the right engine started to vibrate a lot, kind of like when you lean the mixture out too much. (Mixtures were rich at this time) All engine insturments checked normally and the only way to get the vibration to stop was to retard the throttle a little. I noticed that that the airplane had been written up yesterday for the same issue and maintence replaced the #4 cylinder...Any ideas as to what might actually be going on here?
