Report the Runway in Sight...
braunpilot
What day is it?
While most of the time that statement is from approach, I got this not once but a few times over the past week from a tower facility when the weather was 200 overcast and 1/2 mile viz (think mid-west last week). No joke. I asked why they did it and was told to make sure that we have the airport in sight. After I checked on, I listened to every pilot who checked on after me, each one (without fail) sounded depressed when they heard they had to report the runway in sight.
While most of the time I do not care about helping out ATC why would you add to the pilot's responsibility and have them report when they have the runway in sight AT MINIMUMS?! I still don't understand it?
Can someone please help explain this one to me?
:banghead:
To complicate your workout even more:). I don't know, it could have to do with the FAA cracking down; they say that to cover their asses :dunno:.
I wonder what they would say if you said "unable, we will report going missed if we don't see the runway". :crazy:
That's what I would have said. I'm not going to be keying the mic at mins if I don't have to, at 200' and 1/2 mile there's no reason for that sort of thing.
:banghead:
Were you landing at KBFI? If so I can tell you why otherwise i could on speculate.
Is the tower waiting for you to report the runway in sight before they clear you to land? That seems strange if it's 200 and 1/2.
:banghead:
I've done it before to be able to taxi someone through the glideslope critical area to hold short of the runway in order to put them in position once you cross the threshold before the aircraft on final, behind you, hits the marker. I don't know why you would just ask someone to "make sure they had it in sight."
Pretty sure we are talking about CPS. They did this to me last week too. Kind of annoying. There is no ILS critical area, and when they did this to me, there were no departures waiting to go either. But that would have been a good guess.
Well the explanation is kinda long so I'll give you the cliff notes. In Seattle if you are familiar SEA is 5 miles south of BFI and when SEA is landing on 16L/C/R the ILS goes right over BFI at 1900msl. The BFI ILS is to runway 13R so you can see the problem 160 heading for SEA and 130 heading for BFI ie converging courses...not a good idea. The ILS's themselves are separated by only 1100 feet inside the marker at BFI withe SEA ILS. There is an agreement between BFI, SEA and the TRACON that allows (when BFI can see the SEA final) to maintain visual separation with BFI arrivals to 13R and SEA 16L/C/R arrivals. BFI is a vfr tower and SEA is a limited radar approach tower. Well there are times when both airports are socked in with weather that does not allow for the previous to happen so there is a situation. At the TRACON we have a arrival monitor position when the weather is like this the have override capability of the SEA final position and are monitoring the BFI TWR frequency. BFI is supposed to ask the aircarft to report the field insight so that we (approach) know that the aircrat has the field in sight and in case of a missed approach BFI could put the traffic in the pattern or execute a missed approach (at BFI the missed is runway heading to 2000, remember from before the outer marker for SEA is over BFI at 1900) and then make the SEA final a/c execute a missed approach as well. Essentially if an a/c at BFI goes around in the situation above the appriach controll has meer seconds to avoid a deal with the SEA final a/c.
Hence the reason for the question of report the runway in sight in crappy weather.
Hopes this makes a little more sense.
I am talking about CPS. I until last week I have never had them ask me to do anything other than land when mins were lower than 500' and 1 mile viz. I don't know if it's that specific controller or just a new procedure that I don't know about. x2 on no departures.
Like upup said, basically.
That will probably be the last time I report it. Next time I will just say unable do to safety of flight. I will reporting rolling out on the runway if you want. I just can't believe that they were asking for it with ceilings that low.
I've been in there when it is around 1 mile and didn't have to call. Is this only a very low vis situation where they do this? I didn't know BFI was a VFR tower you have those nice radar displays in there
It happens when BFI calls Approach and says that they can't see the SEA Arrivals. Only then will BFI ask you to report the runway in sight.
I like when local asks you to report the jet taking the runway in sight for wake turbulence while you're extended on the left downwind past the numbers with a right crosswind correction.
"Well, the runway is behind me, but I'll put up the periscope."
Were they doing sidesteps? I've seen this into BOS on the ILS 4R. They could push more traffic in there if we could get 4L in sight and sidestep over. The lowest I've seen them do it was 600-700' overcast though; nowhere close to minimums.
Are you talking about BFI?
No, they were doing the straight in. No side step, no circle, the weather was reported at 1/2SM and OVC002.
