Midwest Cx MCI Flights?
Lately, it's seemed that gate agents KNOW the weight restriction is more restrictive than it should be, and they just board everyone up and hope.
I'm sure they get in trouble for that, operations listens in on the radios and the delay goes on them if they do that. There are people I work with who do that too, because they are shy about asking for volunteers. And if they ask and don't get any, they don't have the guts to tell someone that despite buying a ticket they won't be getting home tonight. Those people usually don't last long, but sometimes they can manage to stay for years. If I were you I'd at least call ops and complain about what the gate agent did, someone needs to call them out so they can learn to do their jobs.
Then they just switch it to a crew delay. :) Seems to be the default setting anyway. Hence the reason all our FAs are terrified of getting delays slapped on them. I've filled out crew comms, talked to supervisors and talked to gate agents. In 2 years, nothing has really changed. If there's even a CHANCE it'll work out and the flight will leave 45 seconds early rather than 1 minute late, that's what their goal is. Never compromise management bonuses.
Whenever we are going to be late we call dispatch when i becomes obvious that we won't be pushing on time. They make a note of it on their computers and when the delay is looked over all the specifics are there.
I read on another message board that Republix doesn't have CATII, but they are trying to get it. However, since they are too cheap to have a HUD or Autoland, they have to have a monitored approach, and because of this they are being held up by the FAA.
Real classy outfit they have. They're still just another PoS regional like the rest of them.
Republic Bankrupt in 2 years, tops.
:bandit:
:bandit:
First you worked for TSA I don't think you can call anyone a POS regional, also you don't need a HUD or Autoland to be CATII. Xjet is CatII and Eagle should be in the next year and as you know the 145 dosen't have a HUD or autoland.
:bandit:
:clap: :clap::clap: Most worthless post of the day!
With us, it's an ACARS to the base management. It only helps if they actually READ it though. I've sent off delay reports straight to base management via ACARS, and by the time I land, I've got a voicemail wanting me to call and tell them why fltXXX has a flight attendant delay on it. I call them back and say "Yeah, they started boarding us 15 minutes late. Crew was there on time. It was all in the ACARS message I sent you. Did it not go through." Response: "Oh yeah, I read that." Try explaining to someone in base ops why you were late with a deferred APU with a jetbridge that won't move with the power hooked up.
"You could have closed the door."
"No I couldn't. The jetbridge was in the way."
"You could have moved the jetbridge."
"No I couldn't. We would have had to turn all the power off."
"Uh....what?"
Never worked for TSA as I knew better than to make that mistake, but didn't know enough to avoid one with the almost the same letters. I don't know much about the ERJ145. I never said you need a HUD or Autoland for CATII. Not sure why XJET being CATII matters, or that Eagle may be in the next year. All I said was Republic was trying to get CATII authorization with monitored approaches, but the FAA is giving them a hard time, and if they hadn't been so cheap and gotten HUD or Autoland they would be CATII.
Does this count as double posting?
I called all the regionals a PoS by the way. Not sure why you are on the war path.
Why is it worthless? It is the truth. Do you work for Republic? All I did was parrot information I read, from the source, but originally posted elsewhere.
:bandit:
:bandit:
It might scare some of you born on Garmin 1000, employed on EFIS types, but the round dial 727 -- no FMS, no RNAV, no GPS, certainly no EFIS, HUD or autothrottle.... Nothing other than two VOR receivers, two ILS/LOC receivers, a marker beacon and a single ADF was...
Category II Certified and Capable!
The round-dial 737-200 "turbojet" was Category III Certified and Capable! with Autoland!
:bandit:
Monitored, which the FAA apparently does not want Republic to do, thus the hold up claimed to just be slow government, vs. unmonitored which is possible through the use of a HUD or autoland capabilities. Correct me if I am wrong, I have been wrong many times before. I learned this stuff in like the 8th grade when I bought my first flight simulator.
Only Garmin I ever used was a 430 on my Instrument checkride in a seminole as it didn't have an ADF equipped, and it was a CDI display that I used. Other than that on the PA44s I flew at ALL ATPS it basically allowed you to go fix to fix, or direct during your "timebuilding."
First job was a steam gauge Falcon 20 going all over Canada, the US and Mexico. It was really easy with the same stuff as that 727 you describe. Probably not as reliable though, but even easier to fly when the autopilot worked. Altitude hold is cool! There was also a GPS that worked sometimes, with a CDI display, that didn't do much other than allow us to go direct over the US. Except for Las Vegas, NM. That's Fort Union now, apparently the database wasn't current according to ATC. One plane had a LORAN. I rented a 152 with a LORAN once about 6 years ago in North Florida. I thought I was hot potatos. I parked it next to a bunch of Riddlers in their beeping and chiming C172 G1000 Deluxes.
Just saying.
:bandit:
"Uh....what?"
You're really this closely managed? I kinda like the laissez-faire approach with my chief pilots. I think I've been called once about a mess leaving, and I'm late all the time. ;-)
There's a finger pointing meeting on delays. Apparently, each department is allowed X amount, and once they go over they start arguing over who gets what. Management's bonuses somewhat revolve around D-0 as well. So, if we're one minute late, management wants to know why they can't go get that steak dinner at Texas De Brazil.
OMG!!! That is totally unsafe. A crew having to fly and/or monitor the airplane. Nooooooo. We can't have that! What do you think you are, a pilot?
Just saying.
:bandit:
Wow thats awesome man. Wish I could fly with you someday.
