braunpilot
What day is it?
But how much drag is created by retracting the gear (doors, retract cycle/motion) over just what is created with the gear dangling down.
IIRC (and it's been a while), in the 172RG the short field t/o procedure was to leave the wheels down until the obstacles were cleared because of additional drag created by the gear-up cycle.
-mini
The cutlass manual never mentions a reason why the gear should be left down for the short field takeoff. It simply states that they should be retracted when the obstacle is cleared.
In the C210 I always wait until no more usable runway. Takes for ever in a place like Memphis but it's so worth it, usually already at 600+ AGL by then.
According to our CP the reason for no retracting a Cessna gear during a short-field takeoff is due to the funky way the gear retracts. Apparently there have been accidents because people retracted the gear and then caught the obstacle they were trying to avoid.
I would recommend coming up with as many callouts as possible. Everyone knows callouts makes your flying safer, and frankly, makes you sound cool:
"Power set" (Echoed by you for effect)
"Good engine"
"Airspeed alive"
"60 knots"
"Rotate"
"Positive rate"
"NEGATIVE runway remaining"
"Gear up" (Make sure that as you're saying this, you smoothly and smartly make the gear up motion with your hand)
"Gear up and in the wells, lights out"
"Climb power set"
Master these, and you're on your way to becoming a true professional pilot.
Slight variations. My company does it "GEAR IN TRANSIT". And after flying that way for a few years I agree. The gear is not UP when you place the gear selector in the UP position. Especially in the Cessna gear it takes at least 7-8 seconds for the gear to fully retract. I used to say "GEAR UP" as well but I think "GEAR IN TRANSIT" is much more accurate and gets your mind wrapped around the thought that it's not up as soon as you place the gear selector up.
