Logging flight time
You're really over-thinking this. It's perfectly legal to log gate returns. It's done aaaaaaaaaaaaaaaaaaall the time in 121/135. Nobody gets busted for it because it's perfectly legal.
There were times in EWR where I'd sit out there in the ballpark for 1-2 hours waiting for an EDCT time with the APU running and the passengers onboard. You better believe I've logged gate returns after that.
Were the flights canceled or just delayed? The FAA has an interpretation that basically states that a delay will allow you to add the original taxi time to the flight after the delay. Going back to the gate for a delay is fine to log so long as the flight occurs later with you flying the aircraft. Unfortunately the interpretation does not include canceled flights and that is what we are talking about.
Bingo. That's why I'm doing further research on this issue.
And that's also what I mean by "overly legalistic." Things aren't cut and dry in the FAR's... they are subject to interpretation.
The interpretation is for the FAA to decide, not for us to decide. Again, playing on the conservative side will keep you from getting hurt.
I haven't logged a landing in weeks. Why would the FAA assume a .4 flight is just a taxi out and back unless you write it in the book as such. My logbook shows nothing about whether I had a take off OR a landing. I also round up .9 flights to 1 even.
They can assume a landing from you logging flight time per the definition. If you log taxi time and never had a landing and the FAA finds out, you could get yourself a suspension/revocation. That includes that .1 increase from .9 to 1 hour.
Overall sorry peeps for wanting to make sure my logbook is correct. If I do accidentally have something happen where the FAA started looking over my records, I want them to be correct instead of compounding the hurt. If you want to log questionable stuff that wont matter in a career perspective but would in a regulatory matter, go for it. The regulatory matter could kill the career where the few hours gained by logging this stuff wont advance a career faster than a day.
They can assume a landing from you logging flight time per the definition. If you log taxi time and never had a landing and the FAA finds out, you could get yourself a suspension/revocation. That includes that .1 increase from .9 to 1 hour.[/quote]
So.... do I get to log time that the airplane lands but I don't? Sorry for the non-sequitur but I figure I'll ask.
Well, I am perfectly comfortable admitting on a forum that I have logged as flight time events involving gate returns, cancellations, and maintenance issues, with no landings. I'm sure there's probably at least 20 hours in there of that sort of thing. Audit me. Dare ya, FAA.
That's good Maurus- others on this site will do other oddities that aren't consistent, as you read in the first part of this thread.
I've ensured mine is consistent and accurate exactly to the minute... and will stand (and has stood) to the scrutiny of any fed (or as bad or worse in my opinion, the scrutinizing interviewer).
As you can see, there different applicable techniques even down to logging PIC time... 61 vs. part 1 are not consistent with each other. Also with gate returns... that's not consistent with part 1, right?
It's perfectly blessed to log that, I will continue to stand by it.
Changing legal recorded flight time is not something that is legal, obviously.
I don't do troll-like questions. Maurus hit the nail on the head...care to add?
You asked
Let me guess, if you are cleared for an instrument approach but are in VMC, you don't log it?
The answer to it is, "of course not," which you already knew. So it wasn't a question either asking for information or in which you thought the answer was different. It seemed to be designed to fish for disagreement and not much else.
Not quite as trollish as, say, "You don't really put the gear down before you land, do you?" but somewhat akin.
Last thing I need is the FAA to audit my logbook to see the reason why I taxied back to the ramp with no take-off or landing listed but still have .4 hours of time. They could easily write me up for having fraudulent time in my logbook. Especially if it has been done multiple times.
I highly doubt anyone is going to care. And besides, it isn't fraudulent. You didn't log any takeoffs or landings, so it may not be a "flight." But we log other things that aren't "flights" - sim time, etc.
I log time @ 1.3 x tach. Is that totally accurate? No, but it is pretty close (for the power settings I fly at). I log sled rides in gliders at .1 per 1000 feet. Totally accurate? No, but I'm lazy.
How exactly has this thread gone to 4 pages. I guess the bottom line is log what you are comfortable logging. This to me is a trivial matter. I guess the point is there is as much interpretation in the regs as there is in the bible. The way you see things may be different then the way someone else sees things. In this discussion we are talking about tenths of an hour OCCASIONALLY.
If .3 is that important to you that you're logging canceled flights, you probably need to take a better look at the big picture.
-mini
I agree. I like to be conservative with my logging. Besides, you're not going to get turned down from that dream job because you have 3999.6hr and they want 4000.
Some people have mentioned stuff like gate returns. Is there any chance that when the FAA issues the letter of interpretation that they actually differentiate between parts 91 and 121?
Careful with rounding hobbs... what you put down in the aircraft records (paid for or got paid for) is legal and binding.
There is no requirement which I'm aware of that the time in your logbook must exactly match the time you write down on the plane log. Some airplanes rent by tach time, but your logbook can be clock time. Clock time and tach time are rarely exactly the same.
And FWIW I've been rounding everything in my book to the nearest .5 for years. Makes the math so much simpler. If the FAA wants to ding me for it, Let um ding me. At this point I no longer need to log hours for anything that the FAA needs to be concerned about, just landings and BFR's, i.e. currency stuff. Therefore other than that one solid hour every two years with a CFI, the hours I write down in my logbook are for my own personal reference and nothing more.
I'm assuming you aren't a pro piot or have aspirations as such? If so, that's a bit of a different ballgame, and you are correct as far as the bare bones of the regs. Things get a bit more serious in regards to the book when it comes to the pro pilot career.
I'm talking about changing the time between billed time or time in the aircraft logbook and what you put in your book. This can become a great issue as far as airline interviews or any sort of records checks. There are records of all your flight time that was billed and or that you were paid for. At airlines, there are records of all your flight time as well.
If there are significant discrepancies or oddities like all even hour numbers- that's going to raise a flag, which will raise a flag on your logging practices and honesty. Again, there can also be time audits done at your previous carriers and jobs- there are records of all those times! It would be prudent to have that agree....
Make sense?
My aircraft's hobbs meter is wired into the left squat switch. When we leave the blocks, I'm legally able to log flight time until we stop on the other end. When we sit in the pad for 45 minutes at TEB waiting for a hole in EWR ops so we can get going, I log it (when I remember to). We had a flight out of TEB a few months ago that was something like .7 flight and 1.5 block.
If someone at an interview has a problem with that, they either:
1) Don't know the regs (and then what other regs are they making up as they go? Mx? Rest?)
2) Just don't like me.
3) Read something I posted online (oogy boogy).
4) Aren't worth the time.
Either way, it doesn't matter. You can log it. When you start worrying about .1, .2, .3, .4...it's probably time to re-evaluate. When you're talking about hours every week, that's a different story.
-mini
-mini
There's still a record from recorded time in that kind of operation on top of the hobbs, right? All the king airs I flew were based off the hobbs, but we still put the block in and out on the record....
.1 .2 .3 .4 will add up to hours every week.... wouldn't you say?
We have a paper record, but all that goes in the aircraft log is the flight time (for obvious reasons). I don't remember what we enter in the electronic record-keeping area...the FO does all of that.
Good question, I'll have to take a look.
However, even if the owner takes the plane back to strictly part 91 and there's no record other than our CESSCOM paperwork, I'm still logging block-to-block. ...paper trail or not.
-mini
-mini
As you should be... and your FO's should know to put the block times in the book.
on/off times (squat switch times) are strictly mx functions...
I really don't know what they put in the tracking system. I haven't looked at it in 8 months.
...which is what we track.
I guess the point is, don't sweat .1, .2, .3 here or there, just log your flight time legally and don't worry about the rest. If someone has a problem with your logbook and finds a .2 error, you probably weren't getting the job and/or were going to be violated anyway.
If you're worried about .2, .3, .4, you need to re-think things.
-mini
-mini
With this mindset, it'll lead to "If you're worried about 1/2 dot below the glideslope, you need to rethink things."
Which will become "If you're worried about 1 dot below the glideslope, you need to rethink things."
Which makes you......dangerous, Ice-Man. [sound of jaw snapping-shut]
:D:D
I just don't see why this thread is so out of hand right now. I mean, seriously, nobody cares about any of this stuff.
The hobbs meter in the aircraft I fly is like mini's. Left squat switch. It only starts running with weight off the wheels. Anything before or after the flight is pretty much whatever the pilot decides to call it. There are plenty of pilots who will call the flight out on time even if we actually started moving 5-10 minutes late. There's a .1-.2 discrepancy right there. Again, nobody cares. And really, nobody can prove it.
I log actual instrument at around 10% of my total time. It's a decent enough average to be accurate enough. And you know what, the FAA isn't kicking in my door because of it. Nobody cares. Nobody can prove it.
I'm not trying to be outright deceptive here, either. I just don't care, and neither does anyone else. Now if you're logging SR-71 time when you didn't actually fly one, or you're logging landings for currency when you didn't actually do them, yeah, you probably have something to worry about. Beyond that, .2, .3, who cares? Nobody.
And yes...I am dangerous.
Attention to detail is definitely at risk here... honestly MikeD has a point.
Strict attention to detail shows up in all aspects of how you do your job. It was amazing how common someone that was sloppy in their logging was also a poor performer in other areas due to not caring. That strict attention to detail got me my job. Keep that in mind...
Best of luck... I'm done on this thread.
I think MikeD was joking...
Anyways, I have a lot of friends that only log 3 night landings, full stop every 90 days. They don't log anything else, because they don't care. Legal? Yes. Inaccurate? Sure. Should anyone else care? No.
