Logging flight time
In the following scenario, when does the flight time legally end, and how much flight time can the pilot log?
1. Pilot taxis to the run-up area with the intention of flight to find the vacuum pump died on an IFR day.
2. Pilot taxi's back to the FBO. (.4 on hobbs)
3. 3 days later the pilot does a maint flight and logs the landing.
A landing assumes a take-off occurred in the definition and you can not log flight time unless the wheels leave the ground and then land on the ground later.
It's not that hard guys. You don't have to log a landing to up your TT...
It is in the definition for flight time. If it wasn't required, why put it in the definition?
As far as FAA legal interpretations on this issue, I only see Part 121 issues with delays and not flight cancellations in the interpretations. In those definitions though, so long as the flight was finished to a landing after the delay all the flight time counted with the original taxi time.
Were you charged for the HOBB time you put on the plane. That is my justification to log it. If you get charged for flight time then you log the formentioned flight time.
:sarcasm:
Honestly, yes you can log it, but whether you actually log it is your choice.
:yup:
If the prop is spinning, you're logging.
Keep. it. simple.
When you begin to move the aircraft under it's own power for the intention of flight, your flight starts.
If something happens and you have to return, it stops when you stop the airplane back at parking.
Very very simple, don't over think it and don't screw yourself and your students out of flight time!!
What I've described is by the law and is blessed by the feds.
It is pretty clear to me you need a landing and I have yet to see anything by the feds saying otherwise.
Let me guess, if you are cleared for an instrument approach but are in VMC, you don't log it?
Not toward currency. I log every landing I get but note which ones are currency and which aren't. Same would go toward the logging of instrument approaches.
Part 61 said:
(1) Use of an airplane, powered-lift, helicopter, or airship for maintaining instrument experience. Within the 6 calendar months preceding the month of the flight, that person performed and logged at least the following tasks and iterations in an airplane, powered-lift, helicopter, or airship, as appropriate, for the instrument rating privileges to be maintained in actual weather conditions, or under simulated conditions using a view-limiting device that involves having performed the following—
(i) Six instrument approaches.
(ii) Holding procedures and tasks.
(iii) Intercepting and tracking courses through the use of navigational electronic systems.
If I can fly the approach by visual reference I wont log it toward currency. I went up and shot two ASR approaches in VMC on my own. I can't log em toward currency, but I did note them in my log book.
I'll have to spend some time researching, I do know that logging returns is blessed by the feds. Certainly keeps things simpler- been doing that over 10 years....
Well done on the instrument approaches- you wouldn't believe how many people don't know that.
I sure hope I know it being an active CFII and having signed off more instrument and CFII students than anything else.
Let me know what you find. Unfortunately asking the FSDO is up there with just asking another instructor or pilot their opinion.
He was trying to slip one by me. :rolleyes:
People on this site for some reason have a tendency to be overly legalistic, sell themselves short, pesemistic, and whiny.
I love em, but want to help because it's so frustrating seeing people do that to themselves.
overly legalistic
Last thing I need is the FAA to audit my logbook to see the reason why I taxied back to the ramp with no take-off or landing listed but still have .4 hours of time. They could easily write me up for having fraudulent time in my logbook. Especially if it has been done multiple times.
61.59 Falsification, reproduction, or alteration of applications, certificates, logbooks, reports, or records.
(a) No person may make or cause to be made:
(1) Any fraudulent or intentionally false statement on any application for a certificate, rating, authorization, or duplicate thereof, issued under this part;
(2) Any fraudulent or intentionally false entry in any logbook, record, or report that is required to be kept, made, or used to show compliance with any requirement for the issuance or exercise of the privileges of any certificate, rating, or authorization under this part;
(3) Any reproduction for fraudulent purpose of any certificate, rating, or authorization, under this part; or
(4) Any alteration of any certificate, rating, or authorization under this part.
(b) The commission of an act prohibited under paragraph (a) of this section is a basis for suspending or revoking any airman certificate, rating, or authorization held by that person.
I would rather be more conservative with my approach to my logbook than relaxed and saying "close enough" and tossing the time in. Unless a chief counsel/legal interpretation can be presented about this situation, I will not log the time unless I get a landing in the flight as it is the second half of the definition of flight time.
In the end why would multiple entries of .4 be worth risking a career for exactly? Canceling a flight after taxiing for a departure is rare enough that it wouldn't make a large impact on TT if you played it safe and didn't log the time.
If .3 is that important to you that you're logging canceled flights, you probably need to take a better look at the big picture.
-mini
You're really over-thinking this. It's perfectly legal to log gate returns. It's done aaaaaaaaaaaaaaaaaaall the time in 121/135. Nobody gets busted for it because it's perfectly legal.
There were times in EWR where I'd sit out there in the ballpark for 1-2 hours waiting for an EDCT time with the APU running and the passengers onboard. You better believe I've logged gate returns after that.
Bingo. That's why I'm doing further research on this issue.
And that's also what I mean by "overly legalistic." Things aren't cut and dry in the FAR's... they are subject to interpretation.
I haven't logged a landing in weeks. Why would the FAA assume a .4 flight is just a taxi out and back unless you write it in the book as such. My logbook shows nothing about whether I had a take off OR a landing. I also round up .9 flights to 1 even.
Careful with rounding hobbs... what you put down in the aircraft records (paid for or got paid for) is legal and binding.
That being said, I've gone a full month without getting a landing... but logging quite a few hours.
