Oye I stand corrected. There's a price point where a 140kt twin will work. But $500k ain't it. If you're in the market for a twin and you've got a $500k budget, you ain't gonna settle for 140kts. And lets face it, the low fuel burn doesn't help because if you've got a $500k airplane budget, you stopped paying attention to the fuel bill long ago. If you absolutely have to have brand new, you can get a Cirrus that goes faster and has a chute for backup for less. A lot less.I believe somewhere around 500K for a fully loaded G1000 (well G950) equipped plane. You can get the with a six pack, HSI and a GNS430 for about 425K, IIRC. It had tons of room when I looked at it, and was in it. Even has a roof escape hatch, so you can get out of it in a hurry if you wanted to.
Yeah I know. I was just funin' with ya. But deserved or not, the Rotax still has a ways to go with a large segment of the pilot population in order to prove itself in terms of being as reliable and economical to own as a lyc or conti.PS: Its not a snowmobile engine.
I realize their target is the training environment. But a flight school could put 5 aircraft online for the price of one of these. I hope they do well but I'll hold off calling my broker and buying any stock in the company for a while.
I really, really hope they come out with something in the 160-200 horsepower department, to try to compete with the big boys. I don't mind people who are critical of the engines, but they really ought to try them before the bashing begins. I find them to be very smooth to fly behind. From a pilot standpoint, they are a heck of a lot easier to operate. With a fixed pitch prop, you've got one lever. Many installations don't have a need for carb heat, even though its a carbureted engine. Plus, they aren't stuck with 100LL for operation.Yeah I know. I was just funin' with ya. But deserved or not, the Rotax still has a ways to go with a large segment of the pilot population in order to prove itself in terms of being as reliable and economical to own as a lyc or conti.
That's one flight school. I can assure you, they are the exception not the rule. The fleet will wear out eventually, but seriously doubt that I'll live to see a day where there is a such a shortage of ratty 1950's-1960's twins on the market that flight schools are forced to buy brand new equipment. And if I do live to see such a day, I would wager that most flight schools will simply close their doors before they'll lay out the cash for a $500k training aircraft.Yup, but eventually those old twins will wear out. Heck, one of the flight schools that I did a significant portion of my training at refuses to own/operate (leaseback) planes more than 18 years old. They like to cite GARA. Plus, they won't operate anything that they don't sell.
Change is slow in aviation and there are very good reasons for that. The problem with trying something unproven is that if you make a wrong choice, you could lose your shirt trying to fix it or make it right. When its your money on the line and your choices are known good vs might be good, most guys will go with known good every time. That's just how it is and I can't say I blame most folks.I really, really hope they come out with something in the 160-200 horsepower department, to try to compete with the big boys. I don't mind people who are critical of the engines, but they really ought to try them before the bashing begins.
Tecnam and Partenavia are two different things, the Partenavia is a model of a company called Vulcanair, Tecnam is an other company. The only thing in common is that they are based in the same city.
there is a third company in Italy that is building a twin piston I just can't remember the name.
How are you going to compare a 0-360 (160-180hp) to a Rotax 912 (100hp at best). A closer comparison would have been to the 0-200.
0-200 -170lbs
912ULS -145lbs
Side note *ULS stands for Unuseable Service Life*
Here is a link to some of the recomended maint./pre-flight issues
http://www.ultralightnews.com/enginemaintenance/912serviceintervals.htm
Sure, it sips fuel, but you make up for it in maint. costs.
Invader is technically mid-wing........but still cool!
If you really want to compare it, compare it to the O-200D (the new LSA designed O-200).
In regards to the whole list of maintenance items, how are any of them much different than say an O-320? Other than coolant and the coolant related systems, they seem to be common on almost every engine I've seen.
Cooling hoses, coolant, radiator cap, rubber intake manifold, carb syncing, just a few that come to mind immeadiatly. Oh, and the gear box. The one thing they do have over a conventional airplane engine is the cyl. seal. The Nikisyl (or however it's spelled) has far superior sealing quality than a std. bore/hone cyl. of ANY lyc./cont. on the market.
