Easiest way to explain it...with an example. Lest you refer to Aero for Naval Aviators.
Maneuvering speed:rawk:
In aviation,
maneuvering speed is the highest speed at which full deflection of the controls about any one axis are guaranteed not to overstress the airframe. At or below this speed, the controls may be moved to their limits. Above this speed, moving the controls to their limits may overstress the
airframe and potentially cause a structural failure. It is normally designated as VA in flight manuals, but is not typically shown on most
airspeed indicators.
With full
elevator deflection at maneuvering speed, an
aerodynamic stall will occur, reducing or eliminating
lift forces before damage can occur to the aircraft.
[1] To increase lift of a given wing, the angle of attack, air density, or the airspeed must be increased. The wing of an aircraft stalls at a specific angle of attack, regardless of airspeed. However, the higher the airspeed, the more lift the wing is capable of producing, and at a certain airspeed it is capable of producing more lift than it can support structurally. The declared maneuvering speed is based on the aircraft's maximum gross weight. At lower weights, maneuvering speed is always lower.
Hypothetically, if an aircraft were flying at a weight equal to its maximum structural load, it would be flying at both
stall speed for that weight and maneuvering speed, with no excess angle of attack and lift available to accelerate the aircraft upward. At lower weights, and the same air speed and air density, the aircraft would be flying at a lower angle of attack, well below of stalling condition, and therefore with an excess lift available which could not be structurally supported. Therefore, as gross weight is decreased, maneuvering speed also decreases.
The maneuvering speed decreases as the aircraft's weight decreases from
maximum takeoff weight because the effects of the aerodynamic forces become more pronounced as its weight decreases. The flight manuals for some aircraft (such as the
Piper Cherokee) specify the design maneuvering speeds for weights below the maximum takeoff weight but sometimes it is left to the pilot to calculate. Using a "Rule of Thumb", the reduction in VA will be half the percentage reduction in aircraft weight. For example if, with only one person on board, weight is 16% below maximum takeoff weight, then VA is reduced by 8%.
[2]
